06-07-2011, 03:13 PM | #1 |
Rock Crawler Join Date: Feb 2010 Location: Hayesville
| BRXL help
Trying to calibrate my esc to my DX3E. I have tried doing over and over and I just cant seem to get it to work. Help me before I just sell it off.
06-07-2011, 04:26 PM | #2 |
Quarry Creeper Join Date: Jan 2010 Location: USA
Maybe you can try flipping the throttle reverse switch from its current position to the other (on top of your DX3E) and see if that helps.
06-07-2011, 04:39 PM | #3 |
RCC Addict Join Date: Sep 2006 Location: Depew
Might be doa. Happened to me. John took good care of me considering it was only a few days before a national event.
06-07-2011, 05:02 PM | #4 |
06-07-2011, 05:30 PM | #5 |
Quarry Creeper Join Date: Feb 2008 Location: Albany
E-mail John, I had 2 that had issues. He took care of me quite quickly. Best customer service anywhere!
06-07-2011, 05:38 PM | #6 |
I would hope I don't have that bad of luck to get two bad one's. If anyone thinks that they might be able to walk me through it, you can give me a call. Thanks Brandon 828-835-6706 |
06-07-2011, 07:46 PM | #7 |
Stupid question....is the throttle trim set to "0", EPA's set to 100%.....have you tried with throttle deadband, switching the throttle to reverse (should be "normal" usually)??
06-07-2011, 08:04 PM | #8 |
06-07-2011, 08:09 PM | #9 |
Ok a little progress. I can control the throttle now, but as soon as I even touch the trigger it jumps into wide open full throttle forward. Only way to stop it is to press the trigger into the reverse operation. |
06-07-2011, 08:31 PM | #10 |
| I think that the trigger on the radio has gone bad. I hooked it up to my sons and it worked great. That must be the reason that I had trouble binding the ESC to the radio. Whats your opnions?
06-07-2011, 09:19 PM | #11 |
06-07-2011, 09:24 PM | #12 |
06-08-2011, 03:18 AM | #13 |
06-09-2011, 06:55 AM | #14 |
just send it back to get it looked at. dont open it and discover you just did more damage.
