06-25-2011, 03:35 PM | #1 |
Rock Crawler Join Date: Aug 2009 Location: I'm a michigan boy can you feel that!
| Novak 2s 17.5 in 2 differant vehicals, really differant results?
Ok i got a Novak Goat 2s System with 17.5 motor I had it in my sons Stampede and its nuts. doing wheelies left and right and on demand. Now i took it out and put it in my BLITZ today to test it out and the speed and grunt just didnt seem to be there? as it was in the stampede. could it be gearing? in the pede it was 23/90 and in the Blitz it was 23/88 not much of a differance. maybe somethign got bumped and it went into brushed mode? |
06-26-2011, 07:08 AM | #2 |
What is the weight difference between the 2 rigs? Are you using the same battery? If not, one may be a bit better than the other. Are the tires about the same diameter between the 2 rigs (this affects overall gearing) Did you swap the ESC & motor, or just one part? Are you using the same radio, if not, did you calibrate the ESC to the other radio? |
