06-27-2011, 06:36 AM | #1 |
Rock Stacker Join Date: Jan 2011 Location: QNZ 11377
| servo upgrade? cant make up my mind help pls
i tested my hitec645 servo on my drifter wich takes less to turn and yup my servo, seems week to one side only, so i looked up a upgrade: Hitec HS-5645MG <~~~ direct replacement but would liek to upgrade Hobbico CS-150 <~~~ is it worth? i mean i sounds good anyone have one? any feedback? Savox SC-0251 <~~~~ i actually like this one, 1) would i need a cap? i have a traxxas 4ch link radio. also is this too big for my scx10? it says LARGE STANDARD SERVO? |
06-27-2011, 06:51 AM | #2 |
Unless you're running a 1.9, I would move up to a HiTec 7955TG. About double the torque in the same size package. My son & I run them in 2.2 comp rigs, mine is moving to my MRC Pro 1.9 rig & getting replaced with a HiTec 7950. |
06-27-2011, 07:09 AM | #3 |
Rock Crawler Join Date: Dec 2009 Location: Beaumont, Tx
You dont want the hobbico cs-150, its about the same as the 645. You need the Hobbico Cs-170.
06-27-2011, 08:04 AM | #4 |
i was thinking about the 7955 but is a bit pricey for me now, no one mention about the savox ??? my worries is the size will it fit on my honcho i have a axel mounted servo |
06-27-2011, 08:50 AM | #5 |
Pebble Pounder Join Date: Feb 2010 Location: Calgary
The 645 is different than the 5645. The 5645 is digital and has a wee bit more torque. Price wise the digital is a bit more but not much. I'm using a 645 in my son's Dingo and it works well. I've got 4.65" tall tires and about an ounce of weight in each tire plus a 6cell nimh in the front and it doesn't have any trouble turning things for trail runs. If you're trailing running it and the truck is not too heavy I don't see why a 645 wouldn't work well until you can pony up for a 7955 if you decide the 645 is too weak. Either way use a metal servo horn and you'd be good to go. |
06-27-2011, 08:57 AM | #6 | |
I don't run Savox, so I can't really comment. I know others that do run them and they seem to be a decent servo. | |
06-27-2011, 09:15 AM | #7 | |
i guess so, i was using a 645 and was working i like the 5645 a bit better | |
06-27-2011, 09:20 AM | #8 |
Rock Crawler Join Date: Oct 2010 Location: triad
I had the 5645mg on my LCC when i first got it and went through 3 sets of gears before i realized it just can't handle the jolts and needs of a good crawler. I would have to say that if you do get it, plan on upgrading it after a while and get an extra gear while your at it so you can replace the striped gear.
06-27-2011, 09:21 AM | #9 |
"HOLLYWOOD" Join Date: Dec 2008 Location: Miami
If this is for your honcho I would go with either the 7955 hitec or the JR 8711. But if your on a budget go with the hitec 985. Word of advice I use to think that way about servos until I went through 3 servos in one year after that never went cheap on a servo, if you can't budget it right now wait a little cause in the long run will be worth it..
06-27-2011, 09:28 AM | #10 |
Quarry Creeper Join Date: Apr 2011 Location: Mt Vernon
I may get flamed for this but when I got my SCX10 it had a standard JR servo on it rated @ 48oz. in, it turned the wheels but that was it. I'm running RC4WD 1.9" Interco Iroks that are 4.7" tall. Over the weekend I got a Hitec 5645, it works great for me. I would have liked to got a 7950 but that was a little more than I could swing for now.
06-27-2011, 11:05 AM | #11 |
my first scaler was running a 645 with no problem at all till i parted it out and now that same servo is in my 8.5lb 4wd shaft pulling truck and has been going strong for 3 yrs (not even a gear breaking). sure i could use more torque but dont need it, but on my comp crawler i run a 7955 since crawlers demand more torque than most scalers doing trail driving.
06-27-2011, 11:19 AM | #12 |
yea i would love the 7955 but i just cant swing it yet, but it will be my next servo when i need one, i guess no one use the savox that one looked kinda kool w/ 222oz for same price 5645 will be my choice for now, thank you guys for the help one more thing does it come w/ metal servo horn? just wondering? Last edited by brios86; 06-27-2011 at 11:33 AM. |
06-27-2011, 02:54 PM | #13 |
that savox SC-0251 still turning in the back of my mind any one used one of these??
06-27-2011, 03:28 PM | #14 |
06-27-2011, 03:35 PM | #15 |
06-28-2011, 02:50 AM | #16 |
RCC Addict Join Date: Aug 2010 Location: wherever paypal sais.
I have the savox 350oz/in servo but running off 7.4v thanks to a castle bec and I love this thing haven't had any issues what so ever out of it. I recomend it. But its a high voltage servo so a minimum of 7.4 volts is neccesarry
