07-08-2011, 02:50 AM | #1 |
Pebble Pounder Join Date: Dec 2008 Location: guam
| Novak rooster crawler problem
I have a problem with my rooster crawler .When i plug in the battery it starts getting hot.What could it be?
07-08-2011, 09:47 AM | #2 |
did you get it wet? likely its given up and its time to replace it depending on how hot it gets |
07-08-2011, 10:44 AM | #3 |
Nope
07-08-2011, 10:58 AM | #4 |
Newbie Join Date: Oct 2010 Location: earth
How many volts are you plugging into it ?
07-08-2011, 07:16 PM | #5 |
The battery is a 7.4 4500mah
07-08-2011, 07:38 PM | #6 |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
Does it control the motor correctly as it's getting hot, or does not? If it doesn't, try either unplugging/unsoldering your motor from it, or try a different motor. Is it possible that motor got shorted internally or externally? Seized? |
07-08-2011, 07:47 PM | #7 |
Quarry Creeper Join Date: Oct 2010 Location: Building stuff in the basement
I might be that the battery connection is not soldered well. Make sure that positive and negative are not touching in the soldered end.
