07-12-2011, 12:03 PM | #1 |
I joined the Band! Join Date: Apr 2007 Location: norfolk
| Novak Mongoose 380 Pinion shaft Size??
Hey Guys just got a Novak Mongoose Crawler System in a CRAPPY TRADE..(See Feedback). The Pinion gear screw was stripped so I had to drill it out. Do these 380 brushless motors take a regular size pinion gear like on a 540 motor?? The only ones I have are the smaller dia. hole ones like what goes on the stock Losi Mini Crawler Motor. Any Help would be great before I run to the LHS.
07-12-2011, 12:35 PM | #2 |
1/8th inch, purdy sure.
07-12-2011, 12:41 PM | #3 |
They are a 1/8" shaft motor. However the MRC uses .5 mod pinions. Not 48 pitch, not metric 48 pitch (.6 mod). So you have to buy the pinion kits from Novak or some else that makes a .5 mod 1/8" shaft pinion. And I believe 14 tooth is the smallest that fits.
07-12-2011, 12:45 PM | #4 |
Great my LHS does not have the Novak Pinions....so this trade continues to kick my A$$....
07-12-2011, 01:18 PM | #5 | |
RCC Addict Join Date: Jun 2006 Location: hillsborough
what are u looking for? did you get complete system? if so the pinion comes with the motor as novak recomends only a 14T (pretty sure) to be used with 18.5 mongoose setup. | |
07-12-2011, 01:23 PM | #6 |
Newbie Join Date: Jul 2010 Location: Salem
dynamite makes pinions in the right size that go down to 11t
07-12-2011, 02:22 PM | #7 |
Newbie Join Date: May 2011 Location: Santa Cruz
The mongoose system (motor and esc) come with a 15 tooth pinion. The mongoose 380 cans are larger than a normal 270 (I think) size and that limits the pinion size because the motor will hit the transmission and you wont get good mesh. So 14t on a mongoose brushless is the smallest you can go. I have a brushed motor with a slightly smaller can and it can use a 12 tooth as a minimum. Stock losi pinion is 14 tooth and is made for a stock motor with the smaller shaft so it wont work with the mongoose. |
07-12-2011, 02:54 PM | #8 | |
Yeah (used awful trade) but the screw was stripped out. I drilled it to get it out...hince destroying the pinion. Thanx Guys | |
07-12-2011, 05:45 PM | #9 |
07-12-2011, 06:19 PM | #10 |
