07-13-2011, 03:39 PM | #1 |
Quarry Creeper Join Date: Oct 2008 Location: Reno, NV
| Tekin FXR Capacitor?
The capacitor on my tekin FXR just broke and ill need a replacement ASAP. I heard that you can just go down to radio shack and buy one as long as the specs are the same or better. But if that is what i do, do i have to replace the capacitor on the other ESC too being that i have two in my berg. |
07-13-2011, 03:44 PM | #2 |
"HOLLYWOOD" Join Date: Dec 2008 Location: Miami
as long as its a 16v cap and 360uf your good.
07-13-2011, 09:21 PM | #3 |
Quarry Creeper Join Date: Apr 2011 Location: United States
I dont see a reason to buy 2 they are just storing energy to keep things smooth
07-13-2011, 11:20 PM | #4 |
Quarry Creeper Join Date: May 2011 Location: Salt Lake City
07-14-2011, 05:07 AM | #5 |
Rock Stacker Join Date: Apr 2011 Location: Upper Peninsula, MI
You want to get caps that are low ESR and rated for 105C. I don't believe they have these at RadioShack. A higher ESR cap rated for 85C is usually what they have, they may work but I always use low ESR and 105C. That's what all the ESC mfgrs use, I wouldnt go with anything spec'd lower. I buy mine on Ebay, search for low ESR cap. NOTE: I'm used to 1/8 brushless vehicles that are much harder on the ESC, since a crawler is much easier on the ESC the 85C higher ESR caps might be fine, but better to stick with what the ESC mfgr spec'd IMO Last edited by simplechamp; 07-14-2011 at 05:14 AM. |
07-14-2011, 01:28 PM | #6 |
I just got a 35v 470uf electrolytic capacitor. Will this be help.
07-14-2011, 05:57 PM | #7 |
I got it in and as soon as I plugged in the battery the copacitor puffed up and smoked. Every thing is fine but I'm still without a capacitor.
07-14-2011, 06:59 PM | #8 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
For the heck of it I'm searching ebay an I don't see any 16v 105c 360uf. But is 360uf the minimum (the uf is the amount it can store right?)? IE, could I get a 105c 16v 470uf ... like these: http://cgi.ebay.com/Fujicon-Electrol...item5ae11e5e43 Feel free to educate me. Last edited by Locked Up; 07-14-2011 at 07:04 PM. |
07-14-2011, 08:31 PM | #9 |
I was reading some stuff today that the UF is fine as long as it's higher or the same. I think I messed up by buying a 35v I thought it just ment I could use a higher voltage battery. Well better luck next time. I think to get the right on i will have to order it.
07-15-2011, 07:42 AM | #11 | |
RCC Addict Join Date: Jan 2005 Location: Germany north
http://www.chemi-con.co.jp/e/catalog...m_diagram.html there are the specs | |
07-15-2011, 12:00 PM | #12 | |
| Quote: | |
04-25-2012, 05:30 AM | #13 |
Quarry Creeper Join Date: Sep 2008 Location: Isle of Man
| Re: Tekin FXR Capacitor?
Sorry to bring back an old thread - caps pop because: 1. they've been subjected to overvoltage 2. cross polarised, i.e. negative polarity on the cap must be negative powered 3. short circuit A 35v 470uf should be ok if fitted correctly |
04-25-2012, 07:06 AM | #14 |
Quarry Creeper Join Date: Apr 2011 Location: Western Australia
Iv been using 1000uf 25 v with no issues.
