Thread: hitec hs-645mg not working. gets very warm
Old 07-21-2011, 04:17 PM   #1
Default hitec hs-645mg not working. gets very warm
this servo looks new.. got it in a lot of rc i bought. plug it in. is seems like its jammed. case gets warm. took it apart nothing looks burn.. any ideas? trying to save it. from what i read hitec is a pretty good servo. thanks for the help
m1009cucv is offline   Reply With Quote
Old 07-21-2011, 04:25 PM   #2
Marbe the motor in the servo shorted out internally. I think the MG-645 fairly cheap. Might wanna think about tossin it or seein if Hitec might warantee it.
gm0688 is offline   Reply With Quote
Old 07-21-2011, 04:45 PM   #3
okk thanks
Old 07-21-2011, 04:46 PM   #4
Jus
Just a shot in the dark but I once burned up a traxxas waterproof servo when I replaced a gear and put it together wrong and it couldn't center itself and it burned up the motor.
Can you turn the output back and forth (with a horn installed obviously) by hand when it's unplugged?
Jus is offline   Reply With Quote
Old 07-22-2011, 12:11 AM   #5
Yep, 1st thing I would check.
If it dosen't move, open it up and check for broken gear teeth or "bits" of stuff floating inside the case. Also check the shaft holes in the case, they may be worn and allowing the gears to cock and jam.
Charlie-III is offline   Reply With Quote
Old 07-23-2011, 06:19 AM   #6
thanks
