07-27-2011, 10:12 AM | #1 |
Rock Stacker Join Date: Jul 2011 Location: Gresham
| Speed Controller Issue
Hello all, I recently purchased an AX10 and have only used a few times. I think there is something wrong with the stock speed controller tho, I have power and steering but no throttle. The sc beeps and blinks red. I have tried re-programming and even re-binding transmitter with no luck. The last time I ran it, it stopped running and I thought it was the lipo cut off, when I reached down to pick it up the motor went full forward without any input from the transmitter and I had to turn it off to get it to stop, it actually did the same thing last night when I re-prorammed it the second time then went back to not working, Anyone have this same issue? I know axial's electronics are not that good, but don't really have the funds right now to upgrade. Any help or input is appreciated. Thanks, Chris |
07-27-2011, 03:36 PM | #2 |
if its blinking just red your throttle trim is off and needs to be adjusted back to its neutral setting for it to start-up, if you have the newer axial ae-2 esc. if its their first one its junk.
07-27-2011, 04:01 PM | #3 | |
I believe those ESC's are similar to Castles in their LED blinks. From their troubleshooting: Flashing Green OR Red = Speed control has not been calibrated and is not armed; or throttle sub-trim is not at 0. Set your TX throttle trim to "0", throttle EPA's to 100%, then recalibrate the ESC to the RX. | |
07-27-2011, 06:04 PM | #4 |
Thanks guys. I am almost positive thats what it is....I feel like such a dummy....lol....same thing happened to me with my b4.1 a while ago...you'd think I'd learn. I'm going to check first thing when I get home.
07-27-2011, 07:33 PM | #5 |
| Check it out & let us know. Your "brain fart" may help someone else out down the road if that is what it was. |
07-28-2011, 10:02 AM | #6 |
Didn't work. Still no power to the motor. I"m gonna call Axial this morning.
