07-29-2011, 09:56 PM | #1 |
Rock Stacker Join Date: Jun 2011 Location: Coquitlam
| M2 dig esc with external BEC glitch
Just built me XR10, everything is wired up all seems well but around half throttle to full throttle i get a slight glitch in my steering with bec in place. If i remove the BEC its all good. Im running a 3s 1300mah lipo, MG642 servo so its nothing serious either, must i use a bec or can i get away with out it? novak says this esc is good with 3s as long as included cooling fan is used.... any thought are appreciated!
07-29-2011, 10:35 PM | #2 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
They say ..... guys on this forum.... that you must use a external bec w/ the m2 w/ 3s (must do). Mine glitches when bound. I need to try to sort it out. I think that the bec is not enough ( the factory one)? Im going to hook up a castle bec and try it? Im running 3s w/ Max amp battery. Ive got a jr 9100 servo w novak black can 45 turn motors. My wraith stopped progress on the xr10. Wraith is a lot of fun!!!!
07-29-2011, 10:38 PM | #3 | |
07-29-2011, 10:40 PM | #4 | |
Rock Crawler Join Date: Oct 2007 Location: Grants Pass
07-30-2011, 02:55 AM | #5 |
Pebble Pounder Join Date: May 2011 Location: Spring
had glitch issues with my Castle external BEC. Servos and powered directly by the BEC. I ran only the signal wire to RX and had issues. After being told to also run the ground wire to the RX, it took care of all of my issues. I am using the internal BEC to power the ESC and signal wires to servos. So only red wires that are pulled are the ones off the y-harness that plug into each of my steering servo channels on RX.
07-30-2011, 09:04 AM | #6 |
I wanna be Dave Join Date: Jul 2007 Location: Within The Machine,,,
i was having issues with mine doing the same,,my steering servo shook like a fatkid in a dodgeball game,,,i had the cc bec wired direct into the servo,,i had changed out the cc bec in favor of the 3amp novak bec,,and all systems go since then,,my rig is on point,no glitch,,i would definately reccomend going with the novak bec... |
07-30-2011, 02:28 PM | #7 |
Spoke to a Novak rep thismornin, said unless im running a high voltage servo the bec is a waste of space and 3s w/included fan is fine. Dunno what all the him's and haw's are around this esc but im under warranty for a year YeaHH crawl on
07-30-2011, 02:52 PM | #8 |
| Novak reps are full of crap and will tell you anything basically to make you happy. Did he also tell you as you up the voltage to 3s you also drop the voltage output to your receiver and servo?
07-30-2011, 07:06 PM | #9 |
went out for a rip today and all seemed well, servo torque was as i had on my wraith or my ax10, esc didnt get hot.... if im to BEC this rig im assumill need a novak one to avoid any steering glitches?
