08-06-2011, 08:15 PM | #1 |
Rock Stacker Join Date: Jul 2011 Location: downieville
| xr 10 wire ?
so i read harleys recomended how to wire electronics with duel esc, to cut the red wires and run the bec to the reciever. i have a buddy that kept both red wired from esc to reciever and ran red and black from bec to steering servo and ran the control wire from the servo to the reiciever. this a better way to do things? or does it matter?
08-06-2011, 09:42 PM | #2 |
Rock Crawler Join Date: May 2010 Location: Calgary, Alberta, Canada
personal preference most of the time... there are different situations where one is better than the other, but it's your call.
08-06-2011, 09:45 PM | #3 | |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
the reciever will get power just fine from one of the ESC's having both hooked up could run you into some trouble. | |
08-07-2011, 11:09 AM | #4 |
Pebble Pounder Join Date: Oct 2008 Location: Downieville
I was reading this post to see if I could be helpful, then I saw it was you. Leave your wiring alone. It's just fine (maybe clean it up). What happen last night? I called to see if you wanted to go out, but your to good to answer your phone. I had to crawl around the yard. The good thing is I found most the rip-rap from the river to the road is climbable. The bad is you f-up and you're in the river. What happened to dinner? Mr., I'm making 4# of porcupine meatballs and having everyone over. You own me dinner! |
