05-14-2006, 06:30 PM | #1 |
Quarry Creeper Join Date: Feb 2006 Location: Tweaking my shaft
| 985 Hitec servo
I ordered the new HS-985MG servo from Horizon. www.horizonhobby.com/Products/Default.aspx?ProdID=HRC32985s I talked to Hitec about a week ago and the tech support guy said the 985 was going to be a replacement for the 945. I then saw that the Horizon Hobby site had them in stock, so I called and ordered one. Tower's sie however shows "order pending" status I will see if it shows up or not. I am going to replace the 645 on the front of my TXT with it and let everyone know how it works. Last edited by redbeard; 05-14-2006 at 06:38 PM. |
06-06-2006, 02:03 PM | #2 |
Rock Crawler Join Date: Mar 2004 Location: Where it's wet
Yhea, I was looking at those too. The Hitec guy I spoke with emailed me their press release : PRESS RELEASE Two New Coreless Heavy Duty Metal Gear Servos! Hitec is pleased to announce the HS-965MG Coreless Ultra Speed and the HS-985MG Coreless Ultra Torque servos. These servos are designed to withstand the stresses of larger scale high performance aircraft or on and off-road vehicles. The case top has been improved with 2 Brass Axial Bushings for greater strength and stability to insure longevity and smooth rotation. Both servos also feature a coreless motor for excellent resolution and centering. The HS-965MG replaces the HS-925MG and the HS-985MG replaces the HS-945MG. SPECS: HS-965MG Coreless Ultra Speed Dimensions 1.57” X 0.78” X 1.54” Torque 103oz @ 4.8V 132oz @ 6.0V Speed 0.13sec @ 4.8V 0.10sec @ 6.0V Weight 2.18 oz (62g) SPECS: HS-985MG Coreless Ultra Torque Dimensions 1.57” X 0.78” X 1.54” Torque 133oz @ 4.8V 172oz @ 6.0V Speed 0.16sec @ 4.8V 0.13sec @ 6.0V Weight 2.18 oz (62g) Beginning in 2006, all Hitec servo products will feature the UNIVERSAL Hitec “S” connector compatible with all modern receivers and wiring. Hitec Part Numbers HS-965HB is #32965S HS-985MG is #32985S Accessory Part Numbers: 55313 Metal Gear Set (HS-965) 55314 Metal Gear Set (HS-985) 55710 Heavy Duty Regular Horn Set 56402 Super Star Horn Set Be sure to post up a report redbeard |
