Thread: Axial AE1 ESC.. Please Help
Old 08-16-2011, 05:50 AM   #1
Default Axial AE1 ESC.. Please Help
Does anyone know if the stock Axial AE1 ESC can handle a 9.6v Nimh battery or not. I don't want to burn it up. I know the stock Traxxas XL5 ESC will but unsure about the Axial. Thanks for the help.
dgcghg is offline   Reply With Quote
Old 08-16-2011, 06:13 AM   #2
http://tinyurl.com/3p2g4tu
Check that....first result will give you the answer.
WIDELOAD is offline   Reply With Quote
Old 08-16-2011, 08:36 AM   #3
Input voltage : 5~10 Cell-2VDC/Cell
Im gonna assume they mean 1.2VDC/Cell, Not 2VDC/Cell
maxxflip is offline   Reply With Quote
Old 08-16-2011, 01:21 PM   #4
Proverbial threadkiller
Trubble's Avatar
The only chassis I have a Velineon in is too small to handle the eight cell pack I built. My Slash's XL-5 wouldn't even turn on, my AE-1 turns on and runs, but there's a lot of glitching and twitching, which I've heard can happen with too many volts. I would tend to doubt radio interference in my case, I'm running a 2PL FHSS.
If you're consolidating packs (as I've been) and have eight cells, might be better off to just send one or two for recycling, unless you plan on buying a 3S capable speed control. If you're just contemplating a purchase, and going to stick with NiMh's, I'd say just get a 6 cell, and you'll be fine.
Trubble is offline   Reply With Quote
