08-27-2011, 02:25 PM | #1 |
Quarry Creeper Join Date: Oct 2008 Location: Reno, NV
| Tekin Fx-R Retarded?
I recently bought a tekin fxr and i swear, it seems like it is retarded. First as i read the directions on how to calibrate it I cant even get the "chimes" to sound when i use the switch to turn it on. But when i plug the battery in with the switch already on it works fine. Now of course after i do all this the truck only works for a few seconds of crawling until it becomes super glitchy. And i am using this on a spectrum radio DXr3. Im just todally out of ideas. What do you guys think? Last edited by jdacus; 08-27-2011 at 03:19 PM. |
08-27-2011, 02:42 PM | #2 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
Need to know more. 1. What battery are you running? 2. What and how many servos you running? 3. Do you have a BEC in line? 4. Pictures of how you have it wired helps. 5. Did you buy used or new? 6. Is your dx3r new or used and this includes the RX All these need to be answered to help eliminate wrong answers. |
08-27-2011, 03:02 PM | #3 |
1. 3 cell lipo 2. 2 servos, one for steering one for R2D dig. 3. BEC coming off of the B+ and B- 4. 5. Bought it new from CKRC and had them Hotwire it there in the store for the voltage cutoff and lipo cells. 6. Sorry i forgot i run a Hobbyking 3 channel radio and reciver I was thinking of my bronco. To many crawlers and radios |
08-27-2011, 03:06 PM | #4 |
Where is your cap?
08-27-2011, 03:08 PM | #5 |
Quarry Creeper Join Date: Jan 2010 Location: Rocky Hill
08-27-2011, 03:11 PM | #6 |
08-27-2011, 03:13 PM | #7 |
Might be several things, my best guess is how your radio is set up. I think I see the cap, so make sure that's wired right. Im suprised you didn't just get another specky rx and just bind it to the 3r? but I would re ramp your esc and start programing again. Might be a setting in the hotwire they screwed up. Get one. They are worth it. the only sure way to do things is to do it yourself. |
08-27-2011, 03:14 PM | #8 |
08-27-2011, 03:18 PM | #9 | |
08-27-2011, 03:18 PM | #10 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
Not that its causing the problem, but the solder joints don't look so good. The solder should flow down into the slit on the posts....in the pics I see none... Almost looks like a cold joint.... The tekin stuff sometimes can be picky about its signal when calibrating stuff. Unplug everything but the ESC and try.... Later EddieO |
08-27-2011, 03:21 PM | #11 | |
08-28-2011, 11:45 AM | #12 | |
Be careful of how all your wires run in the rig. Try (as much as possible) to keep power wires (battery & ESC) away from comm wires (RX antenna, RX to servo/ESC wires). If power & comm wires must cross, try to do so at close to 90* as you can. Also, what batteries are you running (NiCD/Nimh, LiPO) and how many cells? What steering servo? Is your BEC direct to through steering servo, or through the RX? If direct, some radios want the power (red) from the BEC to the servo and the black connected to the RX black for the servo. | |
08-28-2011, 12:02 PM | #13 |
Rock Crawler Join Date: Oct 2007 Location: Grants Pass
Not sure it could cause a problem but in the second to last of the first pics you posted it looks like you have a small wire fray crossing between the 2 positive posts. Also are you trying to use the switch for programing some how? From your first post it sounds a little like you are trying to program it like a castle?
