08-29-2011, 12:05 PM | #1 |
Master Rocksmith... Join Date: Jun 2011 Location: Salina
| NovakM2 DIG: My Lipo Blew Up in my XR-10, and now my ESC don't work right???
i put a fresh hyperion 1350 mah 3s lipo in my xr-10 for a quick session, and after 2-3 minutes, i noticed a difference in throttle performance, shortly followed by smoke and sizzling from the lipo... i managed to get it pulled before it caught fire, and got it outside... so no biggie i thought? but as i hooked up another freshly charged pack to it, i realized my rear motor will only go in reverse, no forwards motion from the rear motor? front motor still works fine, dig switch still works in both directions and led indicators all function as they normally would. im running tekin handwound motors , and they are like new as well... i've re-set and re calibrated the esc and RX several times with no change... so my question is, is it possible for a bad lipo to cause a internal problem with my ESC, has this happened to anyone before, and what can i do to fix it? thanks... |
08-29-2011, 01:46 PM | #2 |
Hmmmm....unless the pack polarity was incorrect, a "bad LiPO" usually means a dead/dieing cell that just causes the ESC to do a LVC shutdown. I don't know what your issue was/is. Try swapping the connections to the motors (swap front to rear/rear to front) and see if the issue follows the connections or not. If it follows, the ESC may have an issue, if it doesn't then your motor has an issue. PS, what kind of CFI are you?? I used to be a CFI-G, but let it lapse a few years ago. Last edited by Charlie-III; 08-29-2011 at 01:49 PM. Reason: Added CFI question. |
08-29-2011, 02:38 PM | #3 |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
Or your ESC had malfunction and killed your lipo.
08-29-2011, 02:51 PM | #4 |
08-29-2011, 03:56 PM | #5 | ||
i've been waiting for a reason to put another dent in the bank account i guess ill be getting more FX-R's soon... and should probably buy stock in Tekin, to recover some of my cheetos... | ||
