08-31-2011, 10:13 PM | #1 |
Rock Stacker Join Date: Sep 2008 Location: salem
| mamba max pro, with traxxas 2.4 linnk
Anyone have problems with this set up. Cant get it to calibrate....get a double flasfing yellow. with a BL sensored motor I pull the trigger forward get a green light and the wraith goes back wards.....try to calibrate but its not likeing it... Any thoughts |
08-31-2011, 11:43 PM | #2 |
Quarry Creeper Join Date: Dec 2008 Location: Australia
Could be several things. Do you have the TX set to 50/50? Throttle trim set to 0? Flashing yellow LED suggests that the ESC is arming before the TX/RX make their connection. Change the Arming Time in the ESC to 2 or 2.5 seconds helps with this problem. Or the throttle trim is not set to 0. Motor direction can also be changed in the ESC. If all else fails reset the radio and start over with the stock radio settings. Restoring Factory Defaults When programming your 2.4GHz transmitter, you may feel the need to start over with a clean slate. Follow these simple steps to restore the factory settings: 1. Turn transmitter off. 2. Hold both MENU and SET. 3. Turn transmitter on. 4. Release MENU and SET. The transmitter LED will blink red. 5. Press SET to clear settings. The LED will turn solid green and the transmitter is restored to default. |
09-01-2011, 02:12 PM | #3 |
trim set to zero.. also set to 50/50. guess i need a castle link! |
09-02-2011, 12:33 PM | #4 |
Link to MM troubleshooting, LED info near the bottom. http://www.castlecreations.com/suppo...mamba_max.html What kind of motor, if you need to "reverse" it, just swap the 2 motor wires if it's brushed. |
09-03-2011, 10:31 PM | #5 |
Simple fix.....castle link. reverse the motor direction put on sensored motor ( cheat mode advanced timing ten degrees) added reverse and put on the crawler mode on 3s pretty quick! faster than stock ! Cant wait to get it on the rocks! electronics traxxas link radio system, four channel rewired. mamba max pro novak 13.5t |
