09-01-2011, 01:27 PM | #1 |
Pebble Pounder Join Date: Feb 2010 Location: Rapid City
| Attention brushless gurus!!!
I am building a FOFF rig and want to use a brushless system. However, I would like to go with something sort of inexpensive. Option 1: Dynamite 5800kv(about $120) set up like the one ini my SC truck. Option 2: The new 4 pole 2900kv(about $130) system built by Castle for Duratrax. I have used the Dynamite set up in my Honcho(with paddles) to see how it performs. It was much faster than a stock Honcho. Of the 2 options which could withstand being geared more aggresively for more speed? Last edited by Hounddad; 09-01-2011 at 01:31 PM. |
09-01-2011, 01:41 PM | #2 |
Probably the 4 pole system. Higher slot count, likely better magnets, and a nice low KV.
09-01-2011, 05:07 PM | #3 |
just so you know the duratrax (castle) system is a 3900kv not 2900kv 4 pole motor, to bad the esc is rated to 2s. on 3s that motor would likely work well in a foff
09-01-2011, 05:33 PM | #4 |
Check out tenshock motors. They are comparable to the castle 4 poles but actually have a little more power. I would look at those or the Castle 1410 if you are on a budget, both can be had for $60-70 on ebay.
09-02-2011, 10:41 AM | #5 | |
I have searched for basic brushless info to educate myself about what the difference in kv's mean. I didn't find much and the LHS seems to be leaning towards more kv's = more speed. Could you splain it better for me?== SIMPLIFY, please. VERY CONFUSED. | |
09-02-2011, 11:41 AM | #6 |
Quarry Creeper Join Date: May 2011 Location: Ak
Kv rating = rpms per volt supplied I use sensored brushless in my scx10. Last edited by SC Convert; 09-02-2011 at 11:56 AM. |
09-02-2011, 12:32 PM | #7 |
09-02-2011, 01:08 PM | #8 |
09-02-2011, 01:16 PM | #9 |
That is why I also list the KV values for brushed motors, makes it a bit easier to compare. Brushless motors can be rated by the turn as well, but that isn't always listed.
09-02-2011, 01:17 PM | #10 |
| But don't forget that sensored motors are also rated by turns like 21.5, 17.5, etc. and the lower number is faster. These turns are the wires wrapped around the stator.
09-02-2011, 01:30 PM | #11 |
So the 3900kv 4 pole system will have more torque and the ability to turn a higher geared(pinion+spur) better? If it makes any difference, I am still using NiMh batts. Haven't taken the plunge into LiPo yet. Last edited by Hounddad; 09-02-2011 at 01:33 PM. |
09-02-2011, 02:46 PM | #12 |
The 4 pole brushless appear to have the torque. I've only seen them advertised for shortcourse trucks. The powerband should work well. Good luck on your build and keep us posted.
09-02-2011, 04:36 PM | #13 | |
You should be fine overall regardless of battery chemistry as long as voltage & capacity fit the application. | |
09-03-2011, 04:50 AM | #14 |
Rock Crawler Join Date: Oct 2010 Location: Chezzetcook Nova Scotia
I know there is a HUGE difference in 2 pole vs 4 pole. I have a 2726 kv ( I know, weird rating) 2 pole 550 can motor I ran in my slash 4x4 and it's pretty good, lots of torque. UNTILL!!! I bought a castle 2400kv 4 pole motor.. I makes the 2 pole motor look like a toy.. So much smoother and to say it had more torque would be an insult.. It had GOBS! And Gobs more torque.. Literally tears my slash apart.. However.. You better hope you have a high "C" rated lipo if you're running this beast. It will puff a 20"c" 5000 mah turnigy 3s lipo. Sent from my highly abused iPhone using Tapatalk |
