09-11-2011, 07:46 PM | #1 |
Newbie Join Date: Aug 2011 Location: Laconia
| Batteries
What Batteries are you guys running in your Crawlers? I am picking up my FxR kit this week and need to know a good LiPo battery that goes well with that setup. Thanks Guys
09-11-2011, 09:54 PM | #2 |
I came over from the 1/12th, 1/10th, and 1/8th scale offroad and short course trucks, so all my packs are stick packs and similarly shaped/sized LiPo's. I just recently made and installed a battery plate on the front axle, but as yet have no smaller sized LiPo packs to run on said plate. Since I'm still rollin' on the AE-1 speed control, I have to update my powerplant before I can decide which batteries I'll go with. And that ain't happenin' this year, so I see continued use of my 6&7 cell packs for the forseeable future. |
09-11-2011, 10:55 PM | #3 | |
From there just determine how many cells in series you want to run, typically 2-4s but the FXR only goes up to 3s. Then take some measurements and figure out how much room you have to put it in, then find one that matches those dimensions. Typically for a comp style crawler most people run 800-1200mah packs that will run from 6-10 minutes. In the scale side of things you can find people running from 2000-6000mah packs that will run for up to 2+ hours, it depends on how much room you have and how much weight you want to put in the rig. | |
09-11-2011, 11:18 PM | #4 |
Quarry Creeper Join Date: May 2011 Location: Ak
When you chose your battery take these things into consideration. What turn motor are you going to be running? 10-34t 2s lipo only 35t and up you can run a 3s lipo. Are you running a BEC? Onboard BEC is only 3Amps. Any high torque / high voltage servo will require the use of an external BEC. Do you have a Hotwire module? To access the current limiting function you will need one. What is the max continuous amperage your battery can safely supply? To find this use the following formula: (current rating)x(amp rating)= max continuous amperage draw Ex: 30c 1600mah lipo 30x1.6=48amps max continuous draw 30c 5400mah lipo 30x5.4=162 amps max continuous draw Using the current limiting feature on the fx-r via hotwire you can ensure you don't damage your batteries no matter what batteries you choose. Last edited by SC Convert; 09-11-2011 at 11:24 PM. |
