09-08-2011, 06:46 PM | #1 |
Newbie Join Date: Feb 2011 Location: Rochester Hills
| Not going to use my NiMH packs for about 2 months, how should I store them?
I know that I'm not going to use my NiMH packs for about the next 2 months, so how should I leave them? Any particular charge level? Then what should I do before I use them again, discharge and recharge, or peak them and use them? One is a 6 cell 5000 mah and the other a 7 cell 3500 mah, both relatively new. Thanks in advance!
09-08-2011, 07:13 PM | #2 |
Either run them through a discharger....or....run them down in your rig until the performance drops off. Store. When ready, just charge them up, then hit them again to top them off. |
09-09-2011, 08:58 AM | #3 |
Nimh self discharges at a pretty good rate doesn't it? I thought it best to keep them fully charged and repeak them at least once a month? I've had packs die on me or at least drop a cell if they sat for any length of time without being charged.
09-09-2011, 10:12 AM | #4 |
i almost sure they should be kept charged
09-09-2011, 11:17 AM | #5 |
| Right from the Mfr.'s mouths...... I always heard to store them charged, but apparently the Mfr.'s say it could go either way. I personally agree with the above post about losing cells to self-discharge. I've got a few packs that 'used to be' 7 cells, and my 8-cell pack was salvaged from 4 different packs. I've also got a few packs I've been carrying around since the late-80's or early 90's. In two months, you'll hardly notice, but ten years of sitting in a box in the basement took a lot more than 2-3 cycles to get back. I guess store 'em half, full, or empty, shouldn't matter much. But I would caution you to charge them at a little lower amp rate and watch your temperatures when you do pull them out and charge 'em back up. |
09-09-2011, 11:31 AM | #6 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
Its totally dependent on which NIMH it is really.........some liked to be stored zeroed, some stored deadshorted, some liked to be stored charged...........really just depends. Later EddieO |
09-09-2011, 06:34 PM | #7 |
Fully charge them, run them in a rig to get the voltage down a bit, don't fully discharge. Put them in a ziplock, and put them in the refrigerator. Cold temps slow down chemical reactions that could cause premature loss of capacity/performance. Let them warm to room temp prior to charging.
09-10-2011, 06:10 AM | #8 | |
I have NiCAD & NiMH packs that sat in a plastic storage box for years in my basement shop. Most came back after a number of easy charge/discharge cycles. Once I did that, I redid the cycles at a higher rate. Some of the NiCADS are 15+ years old. | |
09-10-2011, 08:17 AM | #9 |
Yeah, my wife wasn't so thrilled with it at first. But now she's used to a few batteries and a bottle of super glue or two. Everything is in ziplocks.
