09-14-2011, 02:21 PM | #1 |
| twin stick. dual esc setup question
Hey. I am thinking of going dual esc to gain propo dig, but i thik I want to pass on a pistol and go for a stick radio. I would like to know if it is possible to set it up like this: ** Left stick ** - up/down = front esc forward/reverse - left/right = steering ** Right Stick ** - up/down = rear esc forward/reverse - left/right + cutting brake if it ever comes out. I figure this way, i don't need to worry about mixing and such and I can instantly adjust how much propo I want. Is this possible? |
09-14-2011, 02:55 PM | #2 |
Quarry Creeper Join Date: Nov 2008 Location: Natick
Anything is possible! What radio were you thinking of using? I'm using a DX7. I modified it so the left stick (throttle) centers. I have it mixed so that the left stick forward runs both F&R motors forward, and back is reverse. when you move the left stick to the left it gives more front dig and when moved to the right more rear dig. So while moving forward you want to speed up the front you just push the stick to the left. sounds complicated but it work really well! I use the right stick for steering. |
09-14-2011, 03:59 PM | #3 |
I tried full independent, and its a HUGE pita. I ran probably 10 hours or so trying to get used to it. A mix is almost required so you can concentrate what your crawler is doing instead of your fingers. However independent control has its advantages, thats why i worked into my radio before the gt3b. So i had my trigger which was mixed, then pushed a button on the handle and went full indpendent. A had a joystick in the handle which controlled the rear and a the trigger controlled front. I love this setup, soon i'll be implmenting something similiar into the gt3b (will require heavy modification) Heres a pic of my old radio (still have it) |
09-14-2011, 04:01 PM | #4 |
But yes what you want todo is possible...a simple flysky CT6B should be able todo that. If you want something with a screen, the Flysky 9X, then get a smartieparts.com programmer.
09-14-2011, 04:21 PM | #5 |
Quarry Creeper Join Date: May 2007 Location: Grass Valley California
Very easy to do I ran a dx 6 that way. I am sure that there are a few posts and how to on the subject. The biggest issue is the self centering on the left side throttle, specrtrum will mod those for you or you can build the mod yourself again pretty easy if you are advetureus. There are threads on doing that also. It works great if you are just having a good time with your crawler. if you are comping it gets a lot more tricky because it is so easy to go into reverse. good luck and have fun.
09-14-2011, 04:24 PM | #6 |
Thanks for the input guys. The only reason why I want to go this route is for the instant propo adjustment. I think the main issue is that I haven't used sticks since forever. Force5's setup seems like a reasonable alternative though, and I already can see the benefit of having the steering controlled independently. Trying to apply/maintain precise throttle and rapid steering input with one thumb seems a bit difficult. I assume in your setup that full left on the throttle stick would be front dig and full right on the throttle would be rear dig? Losikid, on your hacked gt3b's, the propo value would be preset, and i would have to adjust it via the menu interface or a trim knob correct? |
09-14-2011, 05:43 PM | #7 |
| Exactly Right! This setup allows for instant adjustments without pushing any buttons and you never get lost as to where your bias is.
09-14-2011, 08:39 PM | #8 | |
Then set another switch to give you instant dig (so you'll have a propo switch and a dig switch) Sometime in the coming months when i will have a right up how to put a rtc lever in their to control it or a normal pot....i'm going to try my best to get same results i had with my ct6b/tq based radio (pics above) as i really like this setup. | |
09-15-2011, 01:10 PM | #9 | |
06-09-2012, 02:33 AM | #10 | |
Newbie Join Date: Apr 2008 Location: Norcal / SF East Bay
| Re: twin stick. dual esc setup question Quote:
Last edited by yellow1; 06-09-2012 at 02:35 AM. Reason: specified which part i really needed information on :) | |
06-09-2012, 08:39 PM | #11 |
Rock Crawler Join Date: Jan 2011 Location: Portugal
What i think this is what you want: XR10 Dual ESC Radio Mix and Setup - YouTube I think this remote is a clone of the flysky CT6B that losikid mentioned. I just bought this remote and I will soon try to set it up as it is on the video. (and probably open a topic to ask for help.... ) I did the change to get the left stick to center myself with a piece of delrin a a dremel. It has no screen so you will always need a computer to set it up, but, at 22$ os what ever ir is, plus the programming cable it is very cheap if you want to try it out. |
06-10-2012, 03:40 AM | #12 |
Thanks xkill. But no. The vid you linked shows the front and rear esc on two channels, and various mixes to obtain synchronized movement and independent movement (via the throttle and elevator) What I want to be able to do is something similar to what force5 has. Which is to say: Front and rear escs on separate channels with various mixes to obtain proportional application of power to either front or rear esc depending on position of the rudder channel. I'm sure that after I find the post that details this, out how to do this. I'd smack my head at how obvious it is. But I'm not that good with programming a 2 stick radio yet... |
06-10-2012, 08:53 AM | #13 |
Rock Stacker Join Date: Mar 2012 Location: U.K.
i am doing exactly that on a cheapo twin stick radio that i modded for left stick centering with dual mmp's on my xr10, just takes a bit of getting your head around to begin with but soon becomes second nature good luck with 4ws though, i predict crashes but the donuts you can do are immense and the propo to dig part is really useful and probably better than something like a 4pl/k |
