09-20-2011, 08:02 PM | #1 |
Rock Crawler Join Date: Jun 2011 Location: Las Vegas/671
| motor whistles on full throttle.
I got a honcho and I replaced the motor and esc back to stock (27t, AE-2 esc). The motor makes a whistling sound on full throttle only.(sounds like a turbo..lol). Is this normal? If it's not, then I'll take out the motor and see what could be wrong. I just wanted to check here if anyone else had this problem. Thanks |
09-20-2011, 08:57 PM | #2 |
Quarry Creeper Join Date: Oct 2008 Location: florida
Check the mesh between the pinion and spur.
09-20-2011, 09:26 PM | #3 |
I know why it whistles.....it doesn't know the words..... On to better ideas.....did you lube the bushings/bearings for the armature? Is the pinion/spur mesh correct? Do either the pinion or spur gears have chipped/damaged teeth? Are you sure it's the motor, maybe the trans? |
09-20-2011, 11:05 PM | #4 |
I don't think any teeth is chipped, I just put in this motor last week and haven't really run it till today. I'll double check again. Thanks |
09-20-2011, 11:17 PM | #5 |
remove the pinion from the motor and see if it continues,if so its deffinatly the motor.
09-21-2011, 12:00 AM | #6 |
09-21-2011, 07:36 AM | #7 |
I would try lubing the armature shaft support, likely bearings.
09-21-2011, 08:20 AM | #8 |
Pebble Pounder Join Date: Mar 2011 Location: Aurora, CO
These motors have an internal fan built onto the armature. My motor has the same whistle and has gone to he** and back already. See if the whistle is lessened when you cover the motor can vent holes with your fingers. Most likely it is this fan causing the whistle. Marcus |
09-21-2011, 08:57 AM | #9 | ||
Thanks Guy's | ||
09-21-2011, 09:12 AM | #10 |
Yup. Motor is still going as strong as it did the day I got the truck. Granted it has never seen over 2s, it's seen plenty of packs. Marcus |
09-21-2011, 04:55 PM | #11 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
My Axial 27T did the same thing in my Honcho too, had a slight whirring/whistling sound, never affected performance to my knowledge. Still works great!
