09-29-2011, 06:43 PM | #1 |
Pebble Pounder Join Date: Mar 2011 Location: citrus heights
| novak the dig problem... help!
running dual fxr's (calibrated, used hotwire to be accurate) on my xr. since i don't have the funds for a 4pl at the moment i grabbed "the dig" to get things going. set up the dig per the instructions, and the functionallity aspect works as its supposed to. my problem is that in what ever direction i'm going (forward or reverse) in 4wd, the motor on the leading end of the truck runs at the correct speed while the trailing motor is MUCH slower. this does correct itself if the trottle is 40 to 50% of the way in. the less throttle i give it the slower the trailing motor turns. very frustrating since i'm trying to crawl and most work is done at low speeds... anybody know why this could be??? i've double checked and reprogramed everything i can. thanks in advance
09-29-2011, 06:47 PM | #2 |
btw... using a dx3e
09-29-2011, 06:53 PM | #3 |
Pebble Pounder Join Date: Aug 2011 Location: Geneva, MN
maybe recalibrate the rear fxr or both
09-29-2011, 08:30 PM | #4 |
09-29-2011, 09:18 PM | #5 |
Rock Crawler Join Date: Oct 2007 Location: Grants Pass
Have you calibrated the dig unit itself?
09-29-2011, 10:00 PM | #6 |
thanks for the help guys... it took 3 trys to calibrate the esc's to the transmitter... stubborn little bastards. after the third time it stuck. |
09-30-2011, 08:36 AM | #7 |
I wanna be Dave Join Date: Nov 2008 Location: Too old to care
If your running dual fxr's why is NOVAK in your title |
09-30-2011, 09:13 AM | #8 |
Pebble Pounder Join Date: May 2011 Location: Oskaloosa
09-30-2011, 09:42 AM | #9 |
i thought that since i had calibrated everything it must have been an issue with the dig. the problem was that when i calibrated the seas esc it didn't take after the first two attempts. sorry for the inconvenience. thanks to those who offered suggestions
09-30-2011, 08:25 PM | #10 |
