09-30-2011, 07:30 AM | #1 |
Newbie Join Date: Oct 2006 Location: uk, wakefield
| HK controller steering
ive finally set my HK-T6a controller up for a DIG, problem is my steering channel(Ch1 on the recieve and left stick on the transmitter) has stopped working. every time i switch the radio set on, it throws the servo to the left. ive checked all the wires for loose connections/shorts, and they are all fine. any help would be appreciated |
09-30-2011, 07:53 AM | #2 |
Did you try a rebind of the radio? Did you accidentially set the steering trim to other than "0"? |
09-30-2011, 09:56 AM | #3 |
i don't think i need to rebind, because every other channel works perfect. so i would have thought its fine there. ive plugged it in to my computer and ran 'Digital Radio' and even then its fully to the left of the screen. |
09-30-2011, 10:43 AM | #4 |
How old is the radio? I'm thinking either the TX has an issue (the pot on the joystick may be loose or failed) or, you have the steering trim/subtrim fully left based on your observation on the PC. Did you have to do a mix to get the dig working?? Maybe you assigned the wrong channel to mix and it's affecting the steering?? |
09-30-2011, 12:58 PM | #5 |
my radio os about 3-4 months old, with not much use at all. i tried another pot in place of the joystick one with the same full left result. i have fount if i set the EPA% at 10on the left side and 0 0n the right, it works but only 10-15% movement, and that is only on the left side still. hope that makes sense |
