10-01-2011, 08:58 PM | #1 |
Pebble Pounder Join Date: Jan 2010 Location: Joliet
| 2 servos 2 bec's?
if i run dual servos on my rig (for steering) will i also need to run 2 cc bec's? i couldnt find a wiring diagram so if anyone has one please post a picture or link. im using 3s lipos, a tekin fxr, and thinking of using 2 hitec HS-5625MG servos at 6.0V thanks for any help |
10-01-2011, 09:21 PM | #2 | |
Feed the power from the BEC into the receiver and you'll power both servos from it. | |
10-01-2011, 09:31 PM | #3 |
Quarry Creeper Join Date: Feb 2011 Location: Vancouver, WA
Another option is the CC BEC Pro, it has two outputs so you could power both your servo's directly. It does have a larger footprint though, it's about the size of a sidewinder. http://www.castlecreations.com/products/ccbec.html |
10-01-2011, 09:33 PM | #4 |
| yea they will both be plugged into the receiver. but would i have to set the bec to a higher voltage or just to 6 volts? i plan on having them both work at the same. would setting the bec to 6volts be enough for both servos?
10-01-2011, 09:39 PM | #5 | |
so basically both servos could be powered off one battery and just the signal wires connected to the receiver? and another battery connected to the speed control to power the motor and receiver? | |
10-01-2011, 09:49 PM | #6 |
I wanna be Dave Join Date: Oct 2005 Location: Under the 4444
I run dual servo front steering on my super, I just ran 2 of the regular bec's, pull the signal wire from each servo and put it in it's own connector. Plug the red and black from each servo into the bec's. Signal wires go to a Y harness than into the receiver. Your esc will power up the receiver and the servos will get their power from the bec's. To power the bec's just take 2 deans connectors solder them together along with the bec power wires and shrink wrap over it. Than you can plug the esc into one end and the batt in the other and all will be powered up off one battery. Clear as mud? |
10-01-2011, 10:19 PM | #7 | |
10-01-2011, 10:28 PM | #8 |
Yea that should do it, here's a quick phone pic of how I did the deans soldered together with the bec power wires. You can see how the esc will plug into one side and batt will plug into the other. Less wires to have to modify/solder together this way.
10-01-2011, 10:35 PM | #9 |
| ahh i see. that looks hard to solder lol but im gonna try it. thanks!
10-02-2011, 02:37 AM | #10 |
what radio are you using? You might want to consider keeping each servo on an independent channel so that you can switch off 4WS if you want.
10-02-2011, 05:26 AM | #11 |
10-02-2011, 10:47 AM | #12 |
if you only plan on running 2 of those lower torque servos you will be fine with 1 bec and can just plug it into the rx along with the servos. the bec should be set at 6v since thats what they are rated for since the bec output voltage and output current dont go together, just with high input voltage the output current goes down.
10-02-2011, 09:18 PM | #13 | ||
nope im going for 4ws. | ||
10-03-2011, 08:08 AM | #14 |
| Well hell, guess I shoulda asked for clarification first instead of assuming. Yea that's alittle different, but your right just eliminate the Y for the signal wire and your good.
10-03-2011, 02:41 PM | #15 |
