10-04-2011, 07:47 PM | #1 |
Newbie Join Date: Jan 2011 Location: Sandwich
| receiver problem
noon question, sorry I left my remote on last night and to day I realized it and put new batterys in it l. It turns on but doesn't sync to the reciever. Could I have fried it somehow? Its a standard 3 channel 2.4g rx |
10-04-2011, 07:52 PM | #2 |
Rock Stacker Join Date: Jul 2011 Location: Chesterfield, VA
Sounds to me like it lost bind with the receiver. Rebind it, and it should work.
10-04-2011, 08:26 PM | #3 |
10-04-2011, 08:54 PM | #4 |
RCC Addict Join Date: Jun 2008 Location: Amish Buggy PA
10-04-2011, 09:11 PM | #5 |
2.4ghz 4ch fhss receiver - 2.4ghz pistol remote control - I dont really know the brand or model number but this is the radio below. It is from a RTR kit, Probably explains why im having issues... Transmitter (2.4G) Receiver (2.4G) I tested the receiver with my ohms meter and im getting continuity or power with the esc plugged into the receiver. So im thinking its gotta be just outta connection to the radio... |
10-05-2011, 07:55 AM | #6 |
Ive been contemplateing on getting a better radio and reciever so i can switch between steering modes.. Maybe itll fix this problem ive been having... FS-GT3B Digital 3ch 2.4ghz TX & RX LCD Transmitter & Receiver |
10-05-2011, 01:34 PM | #7 |
I have no clue on the radio. I can't see how "leaving it on until the batteries were dead" hurt anything except killing the batteries. Are you sure you put the new ones in correctly (stupid question, but I have to ask....)? Do you get any lights on the TX or RX? Your manual should state how to rebind/relink the TX to the RX. |
10-05-2011, 02:54 PM | #8 |
Ya I just got a response from Exceed. They said there is a button on the receiver i push... Now lets just hope its workable since i waterproofed the electronic when i got it. ha thanks Oh and ya I got lights and everything on the Radio |
10-05-2011, 02:58 PM | #9 |
10-05-2011, 07:00 PM | #10 |
| Exceed stock radio issue & info
Sooo......is it working now?? Thanks for linking the info, just in case someone else has a similar issue down the road. |
11-11-2011, 10:54 AM | #11 |
| Ya I got it working, but I am having the same issue again...For some reason its not syncing though now. I think I'll just have to look at it tonight with a fresh set of eyes.
11-11-2011, 01:29 PM | #12 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
do you have another receiver of the same brand you can try? start from scratch, take every thing off the receiver, batteries out of the radio. then start like you just go the radio. |
11-11-2011, 01:48 PM | #13 | |
Ya the only time I ever have this issue is when I'm tinkering with the receiver and the servo plugs. I was trying to figure out a way to make my front servo to go in the opposite direction. After doing some searching, I figured out if I do the swamp inside wires then I can run this new setup. Noob Question, Is it bad to unplug or plug in the servo plugs into the receiver while its in the on position? Thanks Last edited by mudeatter; 11-11-2011 at 01:55 PM. | |
11-11-2011, 02:30 PM | #14 |
11-11-2011, 02:41 PM | #15 |
yep, won't hurt it...no scare of shorting out.
11-21-2011, 10:37 PM | #16 |
| Ok my replacement receiver finally showed up. It got shipped from Cali to New York then finally to Chicago... Stupid....Anyways, started hooking things up and the receiver isn't getting any response from the esc. My new thought is that the esc fried. It did do a little herky-jerky right before all this happened. Im thinking that somehow one of the wires from the esc got pulled out of the plug, so i snipped the plug and installed an extra servo plug that I had laying around. Still nothing. SO this leads me to think that the esc is fried. When turning on the esc i still get the doh ray mee sound, it just doesnt turn on any of the lights or make any addition noises when connected into the new or old receiver. Ill have to do some more research on a new esc in the morning. Im currently running a 7.4v stick pack with the stock 540 brushed 60T Motors, and my new FS-GT3B Radio & Receiver. Can I upgrade my esc without upgrading my motors too? Though I'd like to update them both. But im sure that im pretty limited to certain modifications running my stick pack. I've been looking into hooking up a castle bec to help give my truck a boost. but im still learning , only been in the hobby a year or so now. Thanks guys for the help. |
11-21-2011, 11:32 PM | #17 |
You can mix & match ESC's & motors, just as long as they "match" (brushless motors need a brushless capable ESC, brushed motors need a brushed capable ESC). As to running your stick pack, it's like a 2S LiPO in terms of voltage, if the ESC can handle 2S your stick pack is fine. Did you calibrate the ESC to the new RX yet????? |
11-22-2011, 05:42 AM | #18 | |
Is this what your talking about? Does this even matter since i cant even get power to go to the rx? http://www.rccrawler.com/forum/elect...ml#post3213031 Last edited by mudeatter; 11-22-2011 at 06:19 AM. | |
11-22-2011, 06:14 AM | #19 |
| I'm looking at : Novak Rooster Crawler Reversible Electronic Speed Control. Compatible with single and dual Brushed motor crawler applications such as a single 27-turn motor or dual 35-55-turn lathe motors. Can I still run my 60T motors even though they say 35-55 Turn? FEATURES: Two specific crawling driver profiles that feature zero reverse delay and high-powered drag brakes (or "hill or "hold" brakes) Built-in LiPo cut-off protection prevents batteries from going below the critical safety voltage level User replaceable input harness Heavy duty 6V/5A BEC Radio priority and polar drive circuitry High-efficiency heat sink Power output for optional 6V fan Water resistant case Thermal overload protection This seems like it would be compatible. |
11-22-2011, 09:00 AM | #20 |
Quarry Creeper Join Date: Jan 2009 Location: Estonia
The 55t limit is when you have dual motors. But for single motor 27t is the lowest you can run. No maximum turn count though. No problems.
