10-09-2011, 11:06 AM | #1 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
| novak goat crawler.. have a problem
its in my scx 10 i just turned the tranny around. trying to get better performance.. im setting it up to my radio. seems to work but forward is reverse and revers is forward.... flip the reversing switch and it moves without me touching the trigger... set up the esc to radio again then i need to reverse it again... not getting anywhere.. any ideas thanks
10-09-2011, 11:37 AM | #2 |
Pebble Pounder Join Date: Apr 2011 Location: scranton
well i know with my old esc you have to push the trigger full forward tell the light blinks then full reverse tell it blinks basically setting the end points. If yours its like this maby you can hold it full reverse when its setting the forward end point and vise versa just a thought
10-09-2011, 11:52 AM | #3 |
Pebble Pounder Join Date: Aug 2011 Location: Geneva, MN
It isn't the throttle trim on TX is it
10-09-2011, 11:52 AM | #4 |
i can try thanks
10-09-2011, 11:53 AM | #5 |
what do you mean korn?
10-09-2011, 12:01 PM | #6 |
Rock Crawler Join Date: Aug 2010 Location: Saint Marys, OH
If I were you, make sure the trim setting for the throttle on you transmitter is set to zero (centered), then enter the setup on the ESC, most typically follow this pattern with lights/beep patterns: neutral ->full throttle -> neutral ->full reverse. Once that is done and good, dial in your trim to your liking. Also, it's helpful to post what electronics you're running, so we help more accurately. |
10-09-2011, 12:53 PM | #7 |
spektrum dx3e sr300 receiver.. stock servo novak brush less crawler
10-09-2011, 06:16 PM | #8 |
1-Try swapping the motor wires to reverse motor rotation....... 2-When calibrating an ESC, set the TX throttle trim to "0", throttle EPA's to 100% and then start the calibration. |
10-09-2011, 06:50 PM | #9 |
ok has three wires.. any idea witch ones i reverse ?
10-09-2011, 06:59 PM | #10 | |
1-You never stated it was a brushless motor..... 2-What motor?? 3-Is it a sensored or sensorless motor?? "Usually" (I'm not a BL expert), you need to swap the 2 outer motor wires for sensored, you can swap ANY 2 motor wires for sensorless. PS, "Spell checking/grammar checking" is provided free of charge. | |
10-10-2011, 09:48 AM | #11 |
yes it is a 18.5 novak.. there is the 3 motor wires and a few separate small wires..
10-10-2011, 09:57 AM | #12 |
Looks like it's sensored.....try swapping the 2 outside motor wires. It shouldn't hurt anything, it may allow motor reversal and not have sensor issues.
10-10-2011, 10:15 AM | #13 |
Have you checked on Novak's website for the systems manual? It may give you some incite as to which wires go where. Here's a link to that system's manual. http://www.teamnovak.com/download/in...3S%20Instr.pdf |
10-10-2011, 11:51 AM | #14 |
Rock Crawler Join Date: Jul 2006 Location: Hobbywing
DO NOT SWAP THE MOTOR WIRES! Sensored systems should have "mode" for reverse rotation. Simply flipping the switch is not really the right way. The Goat and the motors we released with the Goat system, we still our older thinking on the crawl stuff. So the motors were based off of our race motors. This simply means the motor has mechanical foward timing. So the ESC has a mode (one of the settings) for reverse "rotation". This has the ESC offset for motors timing and run correctly. Simply flipping the radio's reverse isn't really correct either. I don't like just doing the programning backwards either. Just do the one touch like normal, then go to the setting and change it. The manual is on the website, it's a PDF download, and has the walk through. Very strait forward. If this is all for a Brushed motor, well, just swap the wires on the motor if it's a crawling motor. Don't forget, you can always just email us directly for tech questions. I check my emails all weekend, stuff like this is easy and usually gets a reply in the evening. tech@teamnovak.com Thanks Charlie |
10-10-2011, 01:31 PM | #15 |
if it helps here is a pic of how i rigged the esc into my scx 10. till i get some boxes 101_3331 pictures from hobbies & interests photos on webshots |
10-21-2011, 02:21 PM | #16 |
im getting inference from something. no matter what i do.. second i touch the throttle.. it moves by it self.. i have it set up like it says in the manual. tried switching from normal rotation to revers a bunch of times.. not working. starting to think something is wrong with the esc.. any ideas ?
10-21-2011, 09:47 PM | #17 | |
10-22-2011, 01:12 AM | #18 | |
Re-read the ESC manual and see. Are you programming through a link or buttons on the ESC? | |
10-22-2011, 10:26 AM | #19 |
using the buttons on the ESC.. i will check the radio
10-22-2011, 10:38 AM | #20 |
Maybe we can meet up since I have a programming cable.
