05-28-2006, 07:25 PM | #1 |
RCC Addict Join Date: Oct 2005 Location: $t. Helen$, OR
| Got a old ESC, want to use it on my Nylint 1/6
Hey, I hope someone here can help me out here, maybe someone here knows this ESC FET Inverter (NEA-950B) I know nothing about these things, and I dont know what they can handle It was used in a old Kyosho 2wd truck, with a single motor single battery (6-7cell packs used) setup I want to use it in my Nylint 1/6, Dual motors(duh) and either dual batteries(if possible) or just run the 1 I hope someone here can help me, if not then I dont plan on cutting up my Nylint to try and make something work out of it... THANKS GUYS |
05-29-2006, 04:11 PM | #2 |
Pebble Pounder Join Date: Jul 2005 Location: Greece
Do you plan on using the Nylint 12 volt stock battery or a 7.2 volt pack? Are you planing to replace the radio, receiver and servo?
05-29-2006, 04:44 PM | #3 | |
and i would love to get a new ESC, because I think the reason I can not just run the 7.2s is because my old one is a POS, but idk much about it someone can help me????? Oh and right now I am ready to take a M80 to it and pick up the pieces and throw them in the trash | |
05-29-2006, 04:49 PM | #4 |
Your old ESC may only be able to handle up to 7.2 or 8.4 volts. I am unsure what that model does. Putting too many volts into it can fry it. You may need to reprogram the ESC to match the radio that you are attempting to use. Also if there is a current limiter on the ESC you need to disable it.
05-29-2006, 05:45 PM | #5 | |
Thanks for the help, I will keep playing with it,... need longer LINKS | |
05-29-2006, 09:35 PM | #6 |
Rock Stacker Join Date: Apr 2006 Location: Canada, BTW its now that cold
It should be fine. Running dual motors though may push it over the edge. The FET's in such an ond ESC can easily handle a 55 turn motor. The higher the turns, the less it draws. Any ESC can handle a 55 turn motor. Now two 55 turn motors would be equivalent to running 1 22 turn motor. What was in it originally ? It can problably handle both. So like you were saying, if you can get the voltage threw it without frying it than your good to go.
05-29-2006, 10:57 PM | #7 |
well I finished it all up tonight If you want info check my build page, link in sig line Thanks for the help guys Pm me if someone has a good rebel 2(or something in that field) for "cheap" |
