10-21-2011, 09:32 AM | #1 |
Quarry Creeper Join Date: Nov 2010 Location: land of no rocks
| sidewinder bogging.
So I am having issues I'm guessing is the sidewinder I have. At times the power will drop off from full to 15% power or I would have no power. Other times I give full thottle but it will only give me about 70% power then slowly power up to 100%. I thought it was hanging brushes so I replaced them and cleaned the motor. Same thing. Replaced the motor with a,new one. Same thing. Newest firmware 1.32 I,think any sugestions
10-21-2011, 09:41 AM | #2 |
Rock Crawler Join Date: Oct 2007 Location: Grants Pass
Is it a sv2 or sct version. Are you running a brushed motor?
10-21-2011, 09:46 AM | #3 | |
Does this happen after running the ESC for a while (possibly a heat issue)? Does it happen when bound up or steering (possible undervoltage issue)? Does it do the same thing with different battery packs? | |
10-21-2011, 09:57 AM | #4 |
Brushed and older v1 sidewinder. Castle bec for lights and servos. The motor is between warm and hot. Can hold fingers on the,can for a long time. Not uncomfortable. Batteries,tried,a few but the same kind. Gen ace 5000mah 40c packs with the bullets wired directly into esc. Setting on castle link are the basic crwaler mode. Locked timing 0 punch control.
10-21-2011, 07:30 PM | #5 |
so i think i got it figured out. i changed the firmware back to 1.27. according to this thread Castle Creations ESC tip thread(brushed) seemed ok with the settings in the store until i took it to some rocks. would not even move. so i tryed manually programming. everything stock settings except brushed mode. worked fine. except no reverse or drag brakes. got home and unplugged everything so all i had was the esc and reciver. changed each setting back to crawler mode one by one. worked fine each time. plugged everything else back in did it again. plugged the ccbec in and lowered the voltage to 6.5 from 7.2 and its fine. didnt think the bec would cuase problems like that with such huge batteries but i will find out tomorrow if that was really the issue |
10-21-2011, 09:36 PM | #6 | |
