Thread: Technical question
Old 05-30-2006, 02:26 PM   #1
Default Technical question
I have a little project I am working on with a electrical engineer who has no knowledge of anything rc.
2 questions that he asked me, and I was unsure about.
"What is the current capacity of the batteries you use?"
and
"What is the stall current of the motors you use?"
I assume on the battery question it is 7.2 on a 7.2 pack, but I have no idea about a motors stall current.
Fishmaxx is offline   Reply With Quote
Old 05-30-2006, 02:43 PM   #2
2006 2.2 National Champ
BENDER's Avatar
There's some good info on motors here.
http://www.rccrawler.com/forum/showt...=stall+current
I think the capacity is just how big the cells are, 2400, 3000, 3300.
BENDER is offline   Reply With Quote
Old 05-30-2006, 03:01 PM   #3
MODERATOR™
EeePee's Avatar
Depends exactly what battery you're asking about, but today's newer Sub Cs, like the Elite 3600 can do up to about 10C (~36 amps), and still hold near 1.2 volts per cell. If that's what he means?
I don't know if I've ever seen a definate answer on when the Lathe motor stalls. I know I've read 90 amps, but I'm not too sure that's been tested.
EeePee is offline   Reply With Quote
Old 05-30-2006, 05:01 PM   #4
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Good sub C's will handle much higher amp draws. The IB 3600's I have will discharge at 80 amps continous, and burst over 300 when they are hot. Hotliner guys like to push cells till they pop
I havent ever seen an answer on stall currents either. I need to get an ampmeter and put it to rest. I would guess 35 -45 amps for a 55t lathe motor on 6 cells.
JohnRobHolmes is offline   Reply With Quote
Old 05-30-2006, 05:16 PM   #5
MODERATOR™
EeePee's Avatar
Do it. Do it.
Do it.
Old 05-30-2006, 07:19 PM   #6
06 Super National Champ
JasonInAugusta's Avatar
Stall current varies from one motor to the next.
Same with batteries. Better batts will be capable of a higher discharge rate that cheap batts.
Too many variables to give him a definitive answer.
But the first question could be interpreted two different ways...
Was is the current capacity? Meaning, "What is the capacity of the batteries?"
OR...he could mean "What's the max discharge rate?"
Both questions are pretty broad. It's like saying you're going to do a research paper on American History.
I've had EE guys at NASA say that the things we're doing with RC batts aren't possible. That the charge and discharge rates are wrong, etc.
Hopefully your EE guy will better understand things.
JasonInAugusta is offline   Reply With Quote
Old 05-30-2006, 07:23 PM   #7
I didnt believe that sub-C's would discharge at 80a continuous till I saw the flight graphs and discharge graphs from battlepacks.com.
I think the only reason they never got more than a few minutes of that amperage is because the plane will dissapear into the sky!
Edit: just realized I sold all my lathe motors this weekend, and they shipped out today. Oh well, no testy for me
Old 05-30-2006, 07:33 PM   #8
MODERATOR™
EeePee's Avatar
No testy for you...
Old 05-30-2006, 07:34 PM   #9
Crap.
Let me go stall a damn lathe motor...
Be back in a few.
Ok, just connected a new Integy 55 turn lathe motor to an E-flite Power Meter.
I used a 6 cell pack that I use in my Roto-Start. I charged it yesterday.
Pack showed 7.8V on the meter.
With the motor stalled the meter showed 18.4A
Old 05-30-2006, 09:34 PM   #10
Thanks guys, and at least now I don't think I asked a stupid question.
I don't think he needs exact #'s .....just typical to what we might see in crawling.
Old 05-30-2006, 09:48 PM   #11
MODERATOR™
EeePee's Avatar
Funny. If ya read it on the internet it must be true.
Old 05-30-2006, 09:58 PM   #12
90A damn!
BTW, this motor is pulling .6A at no load, which is consistent with what jam1sstang got from his 55 turn on his Indi dyno.
Old 05-30-2006, 10:02 PM   #13
MODERATOR™
EeePee's Avatar
Hey! I got an idea. Test some more motors!
Old 05-30-2006, 10:05 PM   #14
You ship them yet?
Old 05-30-2006, 10:21 PM   #15
MODERATOR™
EeePee's Avatar
coughbrushless
Old 05-30-2006, 10:28 PM   #16
BENDER's Avatar
coughbrushless
x2
Old 05-30-2006, 10:31 PM   #17
dezfan's Avatar
Now that would be some interesting info!
dezfan is offline   Reply With Quote
Old 05-30-2006, 10:41 PM   #18
To do the same test I'd have to make the measurement on the battery side of the controller instead of between the controller/ESC...unless I used an AC ammeter.
I'm thinking I'll use my 40A E-flite ESC for that test. Or maybe that 120A Mtroniks unit that's laying here.
Old 05-30-2006, 10:51 PM   #19
Do it!
Gotta love numbers and technical specs most people could care less about
Mad Scientist is offline   Reply With Quote
Old 05-30-2006, 11:01 PM   #20
Different esc's will get different stall amperage I bet. The mamba would be just fine too. dont be a wimp
