05-30-2006, 03:34 PM | #1 |
Rock Crawler Join Date: Jan 2006 Location: Derbyshire UK
| battery noise
Just finished my sw2 tlt ,when putting the motor under load and turning the steering at the same time there is a strange hissing sound coming from the battery pack, has anyone had this before? have I got a faulty battery? Regards JOHN.:-(
05-30-2006, 05:00 PM | #2 |
Pebble Pounder Join Date: May 2006 Location: Scottsdale
I have had that with plugging in a battery to be charged, its more of a zinging. sorry can't help ya but anyone know what our problems could be related to?
05-30-2006, 05:19 PM | #3 |
Are you certain it's the battery? You can take it out of the truck and be 100% sure it's battery?
05-31-2006, 12:29 AM | #4 |
Yes it is definitley the battery, If I pick the truck up to release the load it stops, and runs okay, but as soon as I put it under load it starts to hiss or crackle again, I think it could be a bad connection in the battery or a shorted cell, has anyone ever had this problem? Regards JOHN.
05-31-2006, 09:16 AM | #5 |
Rock Crawler Join Date: Nov 2004 Location: Driving the Troysion Stick up the BIG BOY line!
Most likely you have a damaged cell. Over heating can cause them to split or crack or just plain go bad causing the hissing noise you have.
06-01-2006, 12:30 PM | #6 |
Thanks for the help guys,Ive found out its the servo making the noise not the battery Ive ordered a new hitec 645 servo to day,It sounds like its shorting out under load, Regards JOHN.
06-01-2006, 01:38 PM | #7 |
Ha! |
06-04-2006, 10:05 PM | #8 |
Quarry Creeper Join Date: Jul 2004 Location: Arkie-Saw
Are you sure that the servo is 'shorting out' and not just fighting the resistance of your load? When put under load, servos make noise, especially digital servos.
06-05-2006, 02:06 PM | #9 |
It was a speed controller fault ,the BEC rating was too low,not allowing enough power to the servo,Thanks
