View Poll Results: Have you had a CC BEC Failure | |||
Yes, With a Tekin ESC | 15 | 25.42% | |
Yes, with a Castle ESC | 11 | 18.64% | |
Yes with a Novak ESC | 3 | 5.08% | |
Yes, with a Holmes Hobbies ESC | 4 | 6.78% | |
No | 29 | 49.15% | |
I don't run a BEC | 2 | 3.39% | |
Multiple Choice Poll. Voters: 59. You may not vote on this poll |
10-30-2011, 07:38 PM | #1 |
| CC BEC Faliure's: Support group
If you've had had a CC bec failure, you're not alone. Share your story with everyone
10-30-2011, 07:41 PM | #2 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
Out of the last 10 I've had 2 bad
10-30-2011, 07:45 PM | #3 |
Also, i'm looking for a cause behind cc bec failures, in my rs vs mmp thread i've heard some interesting stories behind esc firmware causing bec failures.
10-30-2011, 08:35 PM | #4 |
Pebble Pounder Join Date: May 2008 Location: Kalispell Montana
Interesting this is finally coming up main stream, as I had this issue many months ago. Between me, my brother and a friend, we went through 5 or 6 (been so long ago I forget how many) 10 amp castle Bec's while running a tekin RS speed control and redline motor with the newest 212 programming. All of us ended up going back to 208 programming without an issue. So for whatever reason the 212 is causing these to fail. I tried all different combos for wiring the bec's but it didn't matter. I talked with Jim at Tekin and even sent him some labscope voltage waveforms of when the problem occurs but he couldn't duplicate the problem. So everyone went back to 208 and I went with a Mamba Max pro. No problems since for any of us.
10-30-2011, 08:52 PM | #5 |
I've had at least 10-15 CC BEC's, heck probably more. Never any issues what so ever. Guess I got lucky. A few months ago they did start adding a bigger Capacitor. |
10-30-2011, 09:13 PM | #6 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
have had one..and runs great. Just sent one in for a big78 with my MM, but he picked it up used and it was toasted when he got it.....so that one doesn't count roksloski...I think he is just seeing of there is a pattern if anyone has had any problems |
10-30-2011, 09:20 PM | #7 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
OK it was me........... in 3+ years only 1 CC bec went bad..... used with an FXR... |
10-31-2011, 10:47 AM | #8 |
We've had 2 die, not sure if they were part of the "suspected" bad batch earlier this year (spring time??). Currently have 3 running. |
10-31-2011, 01:06 PM | #9 |
10-31-2011, 07:46 PM | #10 |
Pebble Pounder Join Date: Feb 2008 Location: 801rcc
Just had a bad one wipe out a 9100t....
10-31-2011, 08:39 PM | #11 | |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
| Quote: | |
10-31-2011, 08:40 PM | #12 |
RCC Addict Join Date: Jun 2008 Location: Amish Buggy PA
No problems here yet....knocking on wood.
10-31-2011, 08:45 PM | #13 | |
| Quote: | |
10-31-2011, 09:09 PM | #14 |
Quarry Creeper Join Date: Apr 2009 Location: Lincoln
I had one go bad but instead of dying it stopped limiting voltage. Thanks Hitec for fixing another servo. Not sure how long the servo was running on 3s before it died. Dual fxr Berg with 7950 servo.
10-31-2011, 10:02 PM | #15 |
RCC Addict Join Date: Oct 2009 Location: In the thinking chair
I've had the same CC bec on my LCC for 2 years and it's still going. It was on an FXR for the first couple of months and a MMP ever since.
11-01-2011, 06:26 AM | #16 |
Rock Crawler Join Date: Jul 2010 Location: VOLS!
Since hooking up the RS(latest firmware) to brushless 17.5 a few weeks ago I been thur about 4 new bec 1 of them having the updated cap in it and 1 used one that I took of my XR10 that had been working good for awhile.
11-01-2011, 06:53 AM | #17 |
Wow never knew this was an issue...I have 3 CC BEC's...2 of the older ones and one new one with the larger cap. None have given me any issues. **knocking on wood now too** They are all wired the same none of them directly to the servo...just straight to the deans plug off the ESC and the red wire removed from the ESC input. On the new setup I have this is the first time I'm running 7.4V off the bec. Wraith: BRXL - Hitec 7950TH - CC BEC (7.4V) - 27T brushed Tamiya silver can Hope I have no issues... |
11-01-2011, 07:13 AM | #18 |
I've had four CCBECs fail. Two failed during comps, one during a long day of bashing, one when just powering up. They were on three different rigs. Two failures were when running at 3S, two failures when running 4S. All were when run with a Mamba Max. Sorry, it's been a few years, I have no idea what firmware they were running.
11-01-2011, 08:24 AM | #19 |
Pebble Pounder Join Date: Jan 2010 Location: brooklyn
| Symptoms?
What are the symptoms of the bec failing,I have a truck running two 200 oz servos that are humming like crazy,and I can't figure out the cause they're practically brand new!
11-01-2011, 08:26 AM | #20 |
Wow never knew this was an issue...I have 4 CC BEC's...3 of the older ones and one new one with the larger cap. None have given me any issues. **knocking on wood now too** They are all wired the same none of them directly to the servo...just straight to the deans plug off the ESC and the red wire removed from the ESC input. On the new setup I have on my Wraith this is the first time I'm running 7.4V off the bec rather than 6V on my other rigs (one is wired up to a 5645, one to a 645, and the other to a 7955, and the new one to a 7950). Wraith: BRXL - Hitec 7950TH - CC BEC (7.4V) - 27T brushed Tamiya silver can - 3S Hope I have no issues... |
