11-04-2011, 09:22 PM | #1 |
Rock Crawler Join Date: Jul 2010 Location: SLC
| gt3b hack programming
dumb it down for me...how to I program it with the 6ch 4.1 firmware to runa winch on the 3rd channel?
11-04-2011, 10:13 PM | #2 |
with the 0.4.1 fw Scroll to REV Press and hold enter for a touch over a second scroll to 3 press enter scroll to CH3 press enter scroll to MOM for momentary (have to hold the switch) or NOL for non momentary press enter scroll to 100 if NOL is selected (this is your step rate)(if mom is selected this step will be skipped) press enter scroll to NOR (if the switch operate backwards for you, change this to REV) press enter now press end a couple times to get back to home screen Incase your wondering, this is how i got this info Code: - Key mapping specific for each model: > choose menu REV and press ENTER-long > menu REV will blink > choose trims (id 1 2 3 d) or other keys (CH3-C, Back-b, End-E) or if trim is OFF, then also trim keys (id 1 2 3 d with left/right arrow) > press ENTER and modify first setting > press ENTER and modify next setting > .... ----- steps of settings of trims (1 2 3 and D/R): - sequence: function -> buttons -> step -> reverse -> opposite_reset -> previous_val -> rotate id: % % V V V blinking % blinking % V blinking - function: selected function listed at the end of manual - buttons: MOM - momentary, hold left/right trim key to get end values, when nothing pressed, servo is at centre NOL - no long keys, long press is the same as short press RPT - autorepeat is on RES - long press of one of trim keys will reset to centre/reset value END - long press of trim key will set to coresponding end value - step: select trim step for one trim key press (1, 2, ... 100, 200), not available when buttons MOM or fuction is list of items (MPO) - reverse: NOR - no change REV - swap left/right trim keys - opposite_reset: not available when buttons MOM NOO - no change ORS - when trim key is pressed and value is at opposite side of centre/reset, set value to centre/reset, - previous_val: available only when buttons MOM or fuction is list of items (MPO) NPV - no change PRV - instead of setting value to centre/reset when key is released, it is set to previous value, which was active before key press - rotate: available only if fuction is list of items (MPO) NOR - no rotate ROT - rotate from max item to 1.item and back _____________ Functions assignable to trims: ============================== OFF - nothing, it is possible to assign each button individualy as key TR1, TR2 - trim of channel 1/2 DRS, DRF, DRB - dualrate of steering/forward/back EXS, EXF, EXB - expo of steering/forward/back CHn - change channel "n" value in range -100...100 STn - subtrim of channel "n" 4WS - 4 wheel steering mix -100...100% DIG - DIG throttle mix -100...100% MPO - Multi-POsition, switches position up/down SST - steering speed turn 1...100% SSR - steering speed return 1...100% CSn - channel speed for channel "n" 1...100% |
11-05-2011, 12:25 AM | #3 |
awesome...thanks |
