06-03-2006, 02:10 PM | #1 |
Rock Stacker Join Date: Mar 2005 Location: Wethersfield, Connecticut
| Drawing more power?
Hi, i am running a Moped V16R esc. And i have a hitec 945mg servo in front and a crap Futaba FP-S14B in back until i get my z650m in. Will having that weak servo in the back lead to it drawing more amperage from the BEC than usual? Its just this esc has 5v at 3amp BEC and i would think that is enough for 2 servos. So does that weak servo draw more amperage because it has have less power and alot of strain?
06-03-2006, 03:50 PM | #2 |
Pebble Pounder Join Date: Jul 2005 Location: Greece
An electric motor (like the one in the servo) will draw the most amps when it is closest to or at its stall point. As to if that servo will draw more amps than the front one I am not sure. The rule that I go for is to have enough amps available to cover both servos at thier stall points.
06-03-2006, 03:54 PM | #3 |
thanks, where do i find out how many amps my Hitec 945Mg draws and my JR Z650M draw?
06-03-2006, 03:56 PM | #4 |
A weaker servo will draw less amperage. Stronger servos have a higher gear reduction combined with a lower wind motor. At stall the low wind motor pulls the highest amperage. |
06-03-2006, 03:57 PM | #5 | |
Good luck finding that. Servos are rarely rated at stall amperage. The easiest way to find out would be an inline ampmeter, wired in with a harness. | |
06-03-2006, 04:09 PM | #6 |
but do you think i will be fine running GP3300's on a 5V/3A rated esc? I will be running a Hitec 945mg in front which is 122oz at 4.8v and a JR Z650M in the rear which is rated at 142oz at 6v.
06-03-2006, 04:10 PM | #7 |
and would running a 3300uf cap help it any because someone told me it would.
06-03-2006, 04:44 PM | #8 |
I really don't know what's going on w/ your set up? I ran two 200+ oz. servos w/o issue?
06-03-2006, 04:45 PM | #9 |
idk what the problem is, might be the crap servo or something. It was glitchy and once i setup my trim on the servo it worked excelent. But since the rear is having so much strain its making everything glitch.
06-03-2006, 05:52 PM | #10 |
Sounds like a cheap servo causing a problem. It could be many things though. You can either try a new servo, or stick a RX pack on, or both. No way to figure it out without trying new stuff. |
06-03-2006, 06:40 PM | #11 |
well i am getting the case for my z650m tommorow so ill see if that is the problem.
06-03-2006, 07:57 PM | #12 |
Newbie Join Date: Jan 2006 Location: kansas city
i used to run the jrz650m servos.......kept burning up one in the front(3 servos @$54).....switched it to a hitec 5945 in front and the jr lasted maybe 2 minutes in the rear, it had a glitch for some reason........now i have both hitecs and no more issues. no more jr servos for me... it has been my experience that the lighter torque servo will draw more current than that of the higher torque. ( on a Y-harness) and burn themselves out. |
06-03-2006, 08:17 PM | #13 |
hmm i hope my rear doesnt burn out :(
06-04-2006, 07:43 PM | #14 |
well now i am running the z650m and the 945mg on a y harness and i get crazy glitches when i turn. Whats the problem? I just cant find the problem, the esc and servo glitches only when the servo's are under load.
06-04-2006, 08:16 PM | #15 | |
Also try connecting a receiver pack just to see if that eliminates the problem. If it does it may be that the ESC cannot handle the two servos at once or the receiver is not transferring the needed power. To test if it is the receiver try plugging the rear servo into the 3rd channel (if you have one). | |
06-04-2006, 08:21 PM | #16 |
Is your Receiver antenna touching anything that can conduct electricity? Can you reposition it or switch it out for another receiver?
06-04-2006, 08:28 PM | #17 |
Quarry Creeper Join Date: Feb 2006 Location: Angier N.C.
What is the BEC rating on the Moped? If it is under 6 volt, that is your problem. You have two high torque servos trying to to turn massive tires drawing alot of power from a small esc, and the small esc is glitching cause it can't keep up with the load it is beeing asked to deliver. What kind of truck are you running? How big are the tires? You're probably gonna have to switch to a reciever pack or a nitro regulator instead of trying to let the esc BEC try to power your rig. |
06-04-2006, 08:37 PM | #18 | |
06-04-2006, 08:41 PM | #19 |
Saw that now, everyone posted while I was typing. lol
06-05-2006, 04:05 PM | #20 |
their is wayy more glitching when the servo's are under large ammounts of stress.
