11-14-2011, 12:16 AM | #1 |
Rock Crawler Join Date: Apr 2011 Location: Sonoma County
| Charging lipos without a balance cable with THUNDER AC3 Charger Possible?
Can it be done? I get the Connection Break on battery check. I have some 2s 20c Dynamite 180mah batteries without balance cables for my micro. |
11-14-2011, 04:39 AM | #2 |
Pretty much any LiPO charger can do "just a charge", although a balance charge is preferred. Some of the small packs have a balancer built in. Double check your adaptor between the charger & the pack. |
11-15-2011, 12:52 PM | #3 |
Pebble Pounder Join Date: Feb 2010 Location: Mpls
I have this charger & every once in awhile I see this as well. I simply disconnect battery from charger, reconnect & then hold down the start button. This usually works. I do not use the built-in balancer & instead use a Blinky + adaptor on all of my batteries.
11-16-2011, 09:33 AM | #4 |
Hmm What is this adapter you speak of? I am just trying to go from the charger to a banana plugs to microdean connector.
11-16-2011, 10:24 AM | #5 |
11-16-2011, 06:07 PM | #6 |
I wiggled the connection around enough to get one to read low voltage, then charged it a bit in nimh mode to get it up and then charged on lipo mode. The other one wont connect despite lots of connector adjustment. I got them in the for sale section so they might just be junk...
