11-20-2011, 08:30 PM | #1 |
Rock Crawler Join Date: Oct 2011 Location: smithville
| some help?
I was gonna get 2s but I see most people running 3s in there crawlers. What is the runtime difference between the two? Also is the rc4wd outcry esc good or should i go tekin fxr? Thanks |
11-20-2011, 09:17 PM | #2 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
11-20-2011, 09:21 PM | #3 |
I also noticed from your post in another thread that you have an XR10. You may not have alot of room for a high mah battery. 1100-1600 should give 30min ish..
11-20-2011, 10:05 PM | #4 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
FXR....hands down My 1300 mah 25 c gives me about 30 in my XR |
11-21-2011, 03:39 PM | #5 |
thanks for all the help. i really appreciate it. so i might still get a sidewinder cuz its cheaper but idk. also what about a hacked gt3b, anybody know how many ch's i need to run dual esc's for independent dig?
11-21-2011, 04:06 PM | #6 |
Also does anybody know of any good but cheap batteries right around 1300-1600mah? Thanks
11-21-2011, 08:59 PM | #7 |
| 4 channels is what you want, just make sure you can mix the 2 throttle channels (the GT3B can....as will a 4PL & others)
11-21-2011, 09:00 PM | #8 | |
11-22-2011, 01:40 PM | #9 |
thanks yeah i saw that site and others have recommended it, so i will buy from there
11-22-2011, 02:11 PM | #10 |
also does the 20c-30c thing affect runtime?
11-22-2011, 03:57 PM | #11 |
not really it affects how many amps the pack can put out continously and in bursts. a good rule of thumb is smaller mAH higher c rating
11-22-2011, 09:17 PM | #12 | |
The battery power available under larger loads is a combination of mah & "C" rating. A low mah pack like a MRC 1.9 rig may run a 350mah 60C pack, while a trail rig may run a 3000mah 25C pack and do fine. Get the idea? | |
11-23-2011, 01:41 PM | #13 |
yea thanks for all the help. you guys are great on here
