Thread: DX3R help
Old 11-27-2011, 09:02 PM   #1
Default DX3R help
First off i got this dx3r used with no manual. i got on theyre website and read the manual. i got everything hooked up bound, and when i turn the rig on it acts like i have the throttle on. going crazy. i adjust the controller settings and it helps but goes faster in reverse and slow forawrd
I dont guess im doing something right. kinda getting ticked off about it. some help would be nice and some walk through trouble shooting!
Thanks for help since im a airhead
PhantomRS10 is offline   Reply With Quote
Old 11-27-2011, 09:04 PM   #2
RPP Hobby's Avatar
Sounds like you need to program the ESC now
RPP Hobby is offline   Reply With Quote
Old 11-27-2011, 09:17 PM   #3
See ive done that also. sorry didnt add to the OP
It steers how it wants too. If i reset everything would that help?
Old 11-27-2011, 09:19 PM   #4
Re-bind it. Mine did the same thing when i first got it. I had to bind it a couple times. A year later it still works perfect.
skipxor is offline   Reply With Quote
Old 11-27-2011, 09:26 PM   #5
Sounds like the ESC was not correctly calibrated, what ESC is it?
As to running faster in one direction, it may have timing in the motor, but may be for reverse. What motor do you have?
Charlie-III is offline   Reply With Quote
Old 11-28-2011, 07:43 AM   #6
I'll bet you used the reset function to change the model information, right?
If you did that then you also need to reset the PARAMETERS. When in parameters cycle the steering from lock to lock and the throttle from full forward to full brake/reverse. This is what is throwing everything off.
Don't listen to all these "experts". They miss this one every time.
AreCee is offline   Reply With Quote
Old 11-28-2011, 10:46 AM   #7
I'll try to remember this one, I don't/never did own a Spektrum radio. Although he never mentioned resetting the model info.............
Old 11-28-2011, 10:51 AM   #8
cherry bomb
fred0000's Avatar
you have your throttle trim set to zero and endpoints at 100% on the throttle chanel?
fred0000 is offline   Reply With Quote
Old 11-28-2011, 11:55 AM   #9
As soon as he said he got it "used" I knew this is his problem.
Old 11-28-2011, 11:55 AM   #10
Doesn't matter where the trims were set when restting the model. You still need to cycle through the parameters.
Old 11-28-2011, 01:36 PM   #11
Point taken.
Old 11-28-2011, 06:44 PM   #12
CBR
Yep! That happened to me a few years ago. You can go to the "monitor" screen and make sure it's working right.
CBR is offline   Reply With Quote
