Thread: CC BEC Wiring HELP!
Old 12-02-2011, 12:17 PM   #1
Default CC BEC Wiring HELP!
Hi guys...I just have a question here for all the pros and experts...
So i am planning to hook up my winch to a 3rd (or 4th. TQ4 radio) channel without having to use a seperate battery pack. (weight reasons)
So what I did pretty much is soldered the winch to the esc plugs, that way the winch and the esc is both being powered by the same 2s pack.
I tried it (with JUST THE ESC AND WINCH into the RX) and it worked great!
and so then I thought I'd need a BEC since Id have the RX pretty full...
leds (plugged into esc and servo for brake lights and turning lights)
winch
servo
esc
and so I bought a CC BEC, and it's on the way and was wondering if my wiring plan is correct before i do anything else...
Would it cause any problems? thanks guys...
I wired it up like shown on the drawing however, my LED system is acting up...it's acting as if it's "confused"...now this is how its wired up:
ESC ----> -----(red wire cut)-->
LED System Rx
Servo ----> ------------------------>
Could it be because I cut the red wire from the esc and the led system connector?
The turn signals doesn't work the way it should be...its confused...and if I connect other leds on LED system, one goes out. what could be the problem?
AKbash57 is offline   Reply With Quote
