12-10-2011, 02:48 PM | #1 |
Pebble Pounder Join Date: Sep 2004 Location: next to my pet rock!
| bec question
I've searched around on here and read some bec answers, but none that were exactly what I needed, so here goes. I want to get the CC bec but am I reading it needs to be programmed? Second, my spektrum rx only has thl, steer, aux and bind slots, no batt. Where do you plug the bec in on this type of rx? |
12-10-2011, 02:52 PM | #2 |
Rock Crawler Join Date: Mar 2006 Location: Up North
It comes preset at 5.1v(I believe)....or buy a programmer(castle link) to pump up the volts. You can plug it into the AUX port. Last edited by jeepster73; 12-10-2011 at 02:57 PM. |
12-10-2011, 03:03 PM | #3 |
Thanks for the answers! The problem with using the aux port is, its being used for my dig! One other thing, can you just use the CC bec without programming it? I know if I want to up the voltage i'd have to program then, but was wondering if its usually good as is. |
12-10-2011, 03:03 PM | #4 |
Rock Stacker Join Date: Jan 2011 Location: QNZ 11377
Depends way I going to use it for? if u want to power RX then yea aux port, I power only my servo and lights from my bec so it's connected to a batt, my batt has a Y split one for BEC, the other for my Rx
12-10-2011, 03:09 PM | #5 |
If I just wanna power the servo with the CC bec, can I use a Y and plug the bec in one side of the Y, then plug the servo into the other side of the Y and finally plug the Y into the rx?
12-10-2011, 03:13 PM | #6 |
12-10-2011, 03:47 PM | #7 |
My rx doesn't have a Batt port! Throttle, used, steering, used, aux, now used with dig servo. The only other port is bind!
12-10-2011, 03:54 PM | #8 |
12-11-2011, 05:26 PM | #9 |
you can plug it into the bind port is thats all thats open. some say to remove the orange wire from the ccbec rx plug (not cut it) to eliminate any chance of setting it into bind mode
