06-11-2006, 09:19 AM | #1 |
Newbie Join Date: Jul 2004
| Motor/ESC Question. Help!!!
I was wondering if this Associated ESC can handle 1 Kyosho magnetic mayhem motor? ***Not sure if the 550 motor can makes a big difference??? ESC SPECS - This is the Associated LRP AI (Artificial Intelligence) Quantum Runner Electronic Speed Control. For motors above 18 turns. FEATURES: No manual user setup required, just plug in and drive 100% waterproof, can be operated under water with full power Forward, brake and reverse Digital interference protection circuitry stops model in the event of interference, empty transmitter battery, or model outside radio range INCLUDES: AI Quantum Runner Speed Control with blue anodized heatsink, motor capacitors, standard Tamiya type connector, tie wraps, mounting tape, user guide and sticker set SPECS: Case Size: 1.02" x 1.02" x 0.62" (26.0mm x 26.0mm x 15.7mm) Weight: 0.67oz (19.0g) excluding wires Voltage Input: 4-6 cells (4.8-7.2V) Typical Voltage Drop: @20A 0.320V Rated Current: 60A (transistors rating at 25°C junction temp.) Rec. Motor Limit: over 18 turns B.E.C. 5.0V |
06-11-2006, 02:12 PM | #2 |
RCC Addict Join Date: Apr 2005 Location: Eden Prairie, MN
| Yes, that ESC should handle that motor fine. |
