12-25-2011, 08:53 AM | #1 |
Rock Crawler Join Date: Oct 2011 Location: minot
| NO drag brake mongoose?
my manual says it should have it with a blue and amber light.. when i program it though it SKIPS that sequence.. as if it is not a programmable thing. im running a NORMAL non crawler esc at the moment with a stump puller. ive recalibrated several times and messed with the trims and sub trims. yet the esc's actual PROGRAMMING for the drag brake is NOT THERE...??? anybody heard of this? |
12-27-2011, 09:36 AM | #2 | |
Quarry Creeper Join Date: Mar 2006 Location: SoCal
| Re: NO drag brake mongoose?
Please forward your question to csuangka@teamnovak.com Charlie is Novak's crawling expert. Quote:
12-27-2011, 12:30 PM | #3 |
Rock Crawler Join Date: Oct 2010 Location: NW Washington
What ESC exactly are you running with the motor? Make sure your throttle trim is adjusted to nuetral. That effects the drag brake. On radios with a dial trim its very touchy and needs to be perfect. Also the drag brakes on the mongoose are very poor anyways. |
NO drag brake mongoose? - Similar Threads | ||||
drag brake?... | davidmcox | Axial AX-10 Scorpion | 5 | 08-02-2011 01:20 AM |
Mongoose and drag brake? | JEB21 | Losi Mini-Rock Crawler | 4 | 07-16-2010 02:19 PM |
Mongoose drag/hold brake | RickM | Losi Mini-Rock Crawler | 4 | 06-08-2010 08:14 AM |
scx10 honcho no need for DRAG BRAKE?... already has drag... | yellowpasta2000 | Axial SCX-10 | 21 | 01-23-2010 09:28 AM |
Throttle / Drag Brake / Brake Question | phatchantz | Newbie General | 5 | 05-19-2008 11:57 AM |
