Thread: Ubec recommendations
Old 12-27-2011, 02:55 PM   #1
Default Ubec recommendations
whats the (average) amp draw of a 15kg servo ?
rhino20 is offline   Reply With Quote
Old 12-27-2011, 04:19 PM   #2
Default Re: Ubec recommendations
A lot depends on the servo.
Is it:
High torque?
Brushless?
Digital or analog?
Why not look up some servo's you're looking at and decide for yourself??
If it's over ~300inoz, you WILL need an external BEC.
No, I won't do the metric/US conversion.
Charlie-III is offline   Reply With Quote
Old 12-27-2011, 05:49 PM   #3
Just buy a Castle Creations BEC regardless of what servo you are using.
irok22s is offline   Reply With Quote
Old 12-28-2011, 09:25 AM   #4
As stated the standard $20-$25 Castle 10amp BEC is pretty much the standard that is used....because it flat out works. This unit will handle any servo that you throw at it.....and it's voltage is nicely adjustable via the separate CastleLink product that can also program your Castle ESCs. ($20 additional...BUT SO WORTH IT!!). Do not rely on a HobbyKing BEC. (or similar). I can speak from experience...they are not worth the cost savings due to more common unit failures. I just went out yesterday and purchased a Castle BEC from my LHS to replace a failed HobbyKing BEC in my Losi Mini.
Keep it simple....put a Castle 10amp BEC in all of your crawlers and save yourself a headache.
xirtic is offline   Reply With Quote
Old 12-28-2011, 11:45 AM   #5
Advice is ok guys, but i live in Europe,and that makes he castle + the link expensive, plus i need 2 of them,& don,t run a castle Esc.
Old 12-29-2011, 02:07 AM   #6
I just purchased this :-
HobbyKing R/C Hobby Store : TURNIGY 5-7.5A (8~42v) HV UBEC for Lipoly
I have yet to try it but it appears to be reasonably well made, Does need 3s Lipo or above.
not as adjustable as CC-BEC but a fair bit cheaper.
Pete.
Pete Attryde is offline   Reply With Quote
Old 12-29-2011, 02:14 AM   #7
CC BEC for sure. It may cost a little more but it flat out fits the bill.
dstrbd1 is offline   Reply With Quote
Old 12-29-2011, 02:28 AM   #8
With a bit of further research,
I have just ordered a CC bec from Tower Hobbies and including shipping (7-14 days) to the UK it came to US$28-70 which is about 22 euro or £19 so not to expensive.
I already have a castle link and don't need the item fast. If I did need it quickly the shipping on it's own went up to approx US$57.
Pete.
Old 12-29-2011, 03:29 AM   #9
Thanks Pete, i was looking at the hobbyking, its sold in the uk by Giantcod rc for 10quid.
Why have you changed to the castle one.
My prob is buying the castle link as well.
I need the Bec for a Losi comp crawler, with a 15kg steering servo.
What are you running yours in ?
simon
Old 12-29-2011, 04:11 AM   #10
I bought my CC BEC from one of the vendors on here (think it was HH), the do the programming for you for an extra $2 IIRC, plus I e-mailed them for a better s&h rate than the standard online quote. Smiles all around!
Maxx_Savage is offline   Reply With Quote
Ubec recommendations - Similar Threads
Don't buy the Integy UBEC BEC nandrewjackson Electronics 3 01-14-2011 03:25 PM
Recommendations sabohead Electronics 5 12-19-2010 03:31 PM
Can i use UBEC BEC to power 2 servo? rcprojectz Electronics 0 06-08-2008 11:07 AM
