01-07-2012, 01:44 PM | #1 |
Quarry Creeper Join Date: Oct 2011 Location: Detroit
| FXR HotWire Profile
Hey, anyone have any good tips for profile settings on the Tekin FXR esc (for MOA dual esc setup, specifically XR10 if possible) Like for Drag brake, throttle curve, etc. I'm about to set mine up via HotWire and I'd love some good feedback from my fellow FXR users. If possible, post pics of your HotWire settings, I'd love to see them. Thanks for the help guys!
01-07-2012, 02:23 PM | #2 |
| Re: FXR HotWire Profile
Also I've heard that the FXR's provided 3S Lipo cutoff setting (option 3) of 9.0v may be a little low to set and that a custom voltage cutoff pack voltage of 9.6-9.9v should be used as a safer measure to guard against one cell that goes lower than the others. Is this true? Might this cause any significant decrease in run time? I suppose better safe than sorry... Anyone out there use a HotWire to set up your Tekin FXR's that would give me some good advice on a good profile to use when setting up my ESCs, or even share your profile setup?
01-07-2012, 04:13 PM | #3 |
Yea, I would set the lipo cutoff to at least 9.6. 9.9 would be my choice (3.3v per cell) and although it will decrease run time a little bit it isnt that big of a deal, just bring a few packs with you. As far as other settings that is all personal preference. I like my front drag to be about 50% and rear at 75%. The only other thing I adjust is dead band or neutral width, I bring it down a bit so that I dont have to pull so far to get going. If you have a radio capable of exponential I would use that rather than changing to a expo profile in the ESC's. |
01-08-2012, 07:39 AM | #4 | |
Sent from my Star Trek communicator from the bowels of outer space ;) | |
01-09-2012, 10:37 AM | #5 | |
| Re: FXR HotWire Profile Quote:
01-09-2012, 12:10 PM | #6 | ||
I wanna be Dave Join Date: Jan 2004 Location: Detroit
01-09-2012, 01:33 PM | #7 |
You will have to play with neutral width to get it to where you like, dont make it too tight or you could have problems with the radio being out of range when you turn everything on. As far as expo that is totally personal preference. I run mine rather high and find that it really helps gain a bunch of control at slow speed. I would just start upping it little by little until you find a setting that works for you. I always re calibrate my ESC after changing settings with the hotwire so I say hotwire it first and then calibrate. It only takes a few seconds to do, I do mine every once in a while just to make sure its not throwing anything off. |
01-10-2012, 08:50 AM | #8 |
| Re: FXR HotWire Profile |
01-10-2012, 08:51 AM | #9 |
Thanks everyone for the input! I hope to have my rig up and running in the next couple days. I appreciate all your advice! Keep it coming. It's all welcome!
01-10-2012, 09:36 AM | #10 |
Just a warning, the 35 setting might be off on different radios and other program aspects. It's a set it and test it type of feature. 45 is probably the best start point until you can run it a bit. |
01-10-2012, 11:40 AM | #11 | |
03-16-2012, 09:06 PM | #12 |
Pebble Pounder Join Date: Apr 2011 Location: australia
| Re: FXR HotWire Profile Can u share your settings ? Pics for front and rear would be great . |
04-19-2012, 11:35 AM | #13 |
04-19-2012, 11:38 AM | #14 |
Easy way to do it, just go down the numbers in the Hotwire screen and list the values......sorta like: 100 100 100 50 Off 3 2 2 F/R This is what I use for my 2.2 Bully MOA with dual 35T motors on 3S LiPO and dual FX-R's. |
04-19-2012, 12:02 PM | #15 |
Thanks Charlie, that I can do! Here goes: My Tekin FXR esc settings: FRONT : 50 100 100 50 Off 9.9v 3 3 F/R REAR: 75 100 100 50 Off 9.9v 3 3 F/R These seem to work pretty well for me so far. I'm having a tiny bit of ClodStall (rear wheels still seem to go a tiny bit slower than the fronts) but I've ironed it out pretty well using subtrim settings for the front and rear channels. I'm gonna try to go down to 13t pinion in the rear to see if I can get as close to erradicating it as I can. Other than that, no complaints so far! I should mention that I'm using dual 16T Holmes handwound Crawlmaster 540's on 3S Lipo. Last edited by DiggyStyle; 04-19-2012 at 01:51 PM. |
