01-11-2012, 07:47 PM | #21 | |
| Re: A little confused with BECs Quote:
A lot of us have had ESC BEC's give up when under high load with ~300inoz+ servo's. Thus they pull in excess of 5-6A. I would love to get good info, but have not found it yet. I know I have read that some servo's pull in excess of 10A @7.4vdc at stall. | |
01-11-2012, 07:50 PM | #22 |
| Re: A little confused with BECs |
01-11-2012, 09:43 PM | #23 | |
Quarry Creeper Join Date: Mar 2010 Location: Los Angeles
01-12-2012, 12:17 AM | #24 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
Check out Welcome to ServoCity and Servo Database - RC Servo Specs and Reviews . They have most servo's listed with full specs. They unfortunately don't have the 8711 specs listed, but with some googling i found a few claims for 4amps+ at stall.
01-12-2012, 07:00 AM | #25 | |
01-12-2012, 09:08 AM | #26 | |
This is all I have ever seen from Hitec, but this has been around since the 5645MG was the high end digital servo so I am sure it does not apply to todays 300+ oz-in servos. The 5645MG is rated 168 oz-in at 6 volts so I would expect a 7955 to draw about 4 amps to make it's 333 oz-in at 6 volts. It also depends on load. I can run my Quicksand winch (Hitec 5955 servo) and a 5955 steering servo in Guido off one 10A BEC. However in my super I need to have two 10A BECs to run front and rear 5955 steering servos. | |
01-12-2012, 04:00 PM | #27 |
| Re: A little confused with BECs I said that it has the full info for most servos, but not the 8711. If you click on the servo name in servodatabase is will actually bring up more detail such as pulse width, rotation range, stall current etc. It's not listed for every servo on there, but it does have most. As for the 'unknown on the internet saying 4amps'...If enough different people from different locations globally, and in different fields of the hobby (air, surface, here on RCC etc.) are saying that it draws 4amps. I would hazard at guess that that would be at least close to the truth or at least a minimum to work off. If in doubt add another amp or two and say it draws 5-6amps, then buy a BEC to suit. If you don't get a reply from your email to JR and don't want to rely on some unknown on the internet. You can always make up a test rig that will stall the servo out and measure your peak amp draw. Then you can put it up on RCC so then you can also be some unknown on the internet. Last edited by WIDELOAD; 01-12-2012 at 04:32 PM. |
01-12-2012, 08:30 PM | #28 | |
Hopefully JR will reply this time... | |
01-13-2012, 06:30 AM | #29 |
I did a Google search for "servo stall amps" and had a number of hits. One servo (HiTec hs-5755mg) shows 4A @ 4.8vdc & 4.8A @ 6vdc. Link..... HS-5755MG Servo As the volts go up, the stall amps go up. Lots more looking, not much more "real data". Did find a "rule of thumb" here (near bottom)..... Data on JR Servo Current Demands - FlyingGiants which states: Dick Hanson has a rule of thumb that 100oz. of torque required 1 amp of power and if you look at the published specs for the various servos, that's usually pretty close. That is probably not a bad number, but likely is relating to running amps, NOT stall amps. These are RC airplanes, they don't tend to stall servos like crawlers do. Hmmm......maybe I should do some tests, I do have 7955's, 7950's & 7954's...... |
01-13-2012, 04:50 PM | #30 |
01-13-2012, 04:56 PM | #31 |
01-19-2012, 12:54 PM | #32 |
JR responded to my inquiry about the maximum amps at stall for the 8711 servo. Unfortunately they state that they do no have this data (hard to believe). However they do claim that it's less than 6 amps. Here's their reply: |
01-20-2012, 05:14 AM | #33 |
I like the "It's under 6 amps since the plug will melt at 6 amps". It's actually a case of amps vs. time. a spike can go very high and brownout the RX but not melt anything. |
A little confused with BECs - Similar Threads | ||||
Would this becs be any good | TRIGGER | Redcat Crawlers | 0 | 02-21-2011 10:26 AM |
becs help needed | TRIGGER | Redcat Crawlers | 5 | 01-20-2011 11:28 PM |
do becs really work? | CubCadet Pulling | Redcat Crawlers | 10 | 11-26-2010 10:44 PM |
BECs!!! | fallensk8man89 | Electronics | 16 | 07-02-2010 09:08 PM |
need help on becs | axial goats | Axial AX-10 Scorpion | 1 | 08-23-2009 05:57 PM |
