Thread: Motor suggestions?
Old 06-20-2006, 12:52 AM   #1
Nope..
Brainstain's Avatar
Default Motor suggestions?
Ok, I have future plans for a TLT basher that will probably end up seeing a lot of mud. Now, my question is should I go with a 55 turn and gear it to the moon to get wheel speed? With the idea being hella torque from the motor and a higher gear ratio for wheel speed. Or should I go with a 16-14 turn geared way low? The idea being use the motors RPM and the low gear for torque? I know the lathe and taller gears get tires moving pretty fast because pulling trucks use that combo. But, a low turn motor and a shorter gear gets racers moving pretty fast too. What do you guys think?
Brainstain is offline   Reply With Quote
Old 06-20-2006, 06:10 AM   #2
Go with a 35t lathe, then gear to your desire.
xjman is offline   Reply With Quote
Old 06-20-2006, 10:37 AM   #3
Exactly. With a mid-range motor, you'll get some decent torque and still have good wheel speed. And that way, you don't have to set your gearing to one extreme or another, giving you way more adjustability. Have you thought about stepping up a cell or two in your pack? An 8 cell pack can give you that little extra punch you may need. Just be sure that your ESC is rated for it.
Mad Scientist is offline   Reply With Quote
Old 06-20-2006, 01:06 PM   #4
Nope..
Brainstain's Avatar
I never thought about that happy medium! I'll probably run a 7 or 8 cell so that will definately help. What about the waterproof esc's? Can they handle 7+ cells?
Old 06-20-2006, 10:07 PM   #5
You'll have to check the specs on each ESC - not all waterproof units are the same. I think most of the M-Troniks line are good for 8 cells.
