01-26-2012, 09:13 AM | #1 |
| CorrosionX & fxr
Anyone use CorrosionX on fxr ? What did you do for the solder posts and led?
12-09-2013, 09:53 AM | #2 | |
I wanna be Dave Join Date: Aug 2008 Location: Austin, TX, USA
| Re: CorrosionX & fxr Quote:
I thought to suspend the ESC in CX while keeping the tops of the posts out of the CX, but it may wick up there anyway so not sure if it's worthwhile to try to suspend it like that. I may also try applying some motor cleaner to a Q-tip to clean the posts after it's been dunked. Not sure what cleans away CX and may have to do some experimenting to figure it out.... What did you end up doing? | |
12-09-2013, 10:15 AM | #3 |
Moderator Join Date: Jan 2004 Location: chicago
makes sense to me to solder it up before applying a w/p method.
12-09-2013, 10:17 AM | #4 |
| Re: CorrosionX & fxr |
12-09-2013, 10:22 AM | #5 |
Rock Crawler Join Date: Sep 2011 Location: truckee
12-09-2013, 10:51 AM | #6 | |
So I'm curious if anyone knows of a chemical that can remove CX before I start my own testing. | |
12-09-2013, 11:01 AM | #7 |
Newbie Join Date: Jul 2012 Location: Las Vegas
So I'm curious if anyone knows of a chemical that can remove CX before I start my own testing.[/QUOTE] Check out CX's website Corrosion Technolgies Sometimes in their product descriptions they describe how to remove it. |
12-09-2013, 11:03 AM | #8 | |
12-09-2013, 11:06 AM | #9 | |
If I was going to remove it from the posts I'd use flux. | |
12-09-2013, 11:12 AM | #10 | |
I would consider coating the posts with something (perhaps flux) if it can be easily removed after submersion. Liquid tape or PLasti-Dip may work if it could be peeled off afterward. I have an e-mail query to CorrosionX to see if they have suggestions on what will remove it. | |
12-09-2013, 11:25 AM | #11 | |
12-09-2013, 11:44 AM | #12 | |
I had the aerosol, so I opened the case and sprayed it down and put the case back together. no problems yet, I didn't spray the post. If you dunk it I say just wipe the post's off and you should be good to go. | |
12-09-2013, 12:04 PM | #13 | |
Just heard from CorrosionX and they told me MEK will remove it. Score! | |
12-09-2013, 12:26 PM | #14 | |
Rock Crawler Join Date: Jul 2011 Location: USA
This is what i say | |
12-09-2013, 12:45 PM | #15 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
I solder everything up then dip everything in corrosionX. I have also resoldered stuff after it was already dipped and it did just fine. Once I resoldered it I also dipped it again in corrosionX so that the new solder was waterproofed.
12-09-2013, 05:07 PM | #16 |
Quarry Creeper Join Date: Nov 2012 Location: Michigan
I always avoid doing the posts with corrosion x. If you do happen to get some on there use some brake clearer on a a tip and run it down and it will come right off
12-10-2013, 12:25 PM | #17 |
Speaking of CorrosionX, which one is the best to get? Ive seen Marine, Aviation, Heavy Duty, Lubrication, etc. Aerosol, spray, normal bottle with a tip,etc.
12-10-2013, 12:34 PM | #18 |
I like the pump spray best because I can pour it into a small jar to submerge items, then pour it back into the bottle. I also have some of the aerosol HD and it's nice and thick, but I'm not sure if it's available in pump spray form.
12-10-2013, 12:50 PM | #19 | |
I just picked up a pint sized. Ball canning jar, sprayed the CX into the jar, and then dip baby dip! | |
12-10-2013, 12:54 PM | #20 |
What kind did you guys buy? the marine?
CorrosionX & fxr - Similar Threads | ||||
CorrosionX for softening! | the_ghetto_rig | Tires and Wheels | 4 | 01-23-2012 05:43 PM |
