02-01-2012, 07:36 AM | #1 |
Pebble Pounder Join Date: Dec 2011 Location: USA
| stupid question.....
so the balance plug on my 2s battery has 1 red wire and 2 black wires.... the balance port on my charger has 1 neg term which is black and 6 pos term which is red....so this confused the hell out of me....i assumed red was pos and black was neg.... please correct me if im wrong here....on the battery balance cable(a gens ace) it has 1 red and 2 black...is the red the neg wire and the black the pos wires....on the charger it clearly shows black being the neg and only having 1 terminal and the red being pos and having up to six....are my batteries just backwards of my charger or am i missing something.... |
02-01-2012, 07:43 AM | #2 |
| Re: stupid question.....
Not a dumb question at all. I had the exact same one when I went to LiPo's. There are two ways to handle that. 1. Look at the pinout on the side of the charger and make sure you plug in the balance plug properly every time (not recommended) 2. Recommended: Get the balance plug board. That has the large plug which plugs into the charger and then several plugs each for different batteries. There will be a 2S, 3S, 4S, 5S and probably 6S plugs. They are all separate and keyed so you can plug them in only one way. Usually, the way it works is the negative is all the way to one side, then there are individual leads for the first cell, second sell, third cell and so on. When the charger charges it will use those leads from the cell to balance it individually. Technically you can plug direct into the charger if you get the direction correct, but I really don't like doing that. The nice thing about the board is when you wear out the plugs you can just buy a new board. |
02-01-2012, 08:54 AM | #3 |
well ok but i still have the same problem....on my balance boards i have 1 red wire and 6 black wires...on my charger i have 1 black pin labeled neg - and 6 red pin's labeled pos +....so my boards and batteries are exactly backwards of my charger....im very confused
02-01-2012, 10:00 AM | #4 |
The balance plugs should be keyed so you can only plug them in one way. You said the battery is from HobbyPartz, is the charger too? |
02-01-2012, 10:19 AM | #5 |
A picture speaks 1000 words. Post up a couple of the different plugs and ports so we can see what is going on. Since your packs are 2s1p there are 3 wires in the connector,they each go somewhere:
Now I dont know what the actual order is but effectively that is the way it works. Since the cells are in series they share one of the wires as the + of one and the - of the other. |
02-01-2012, 10:34 AM | #6 |
ok yea ill try to post up some pics later today.....and the balance boards are keyed and i can only plug my battery in them one way....but i can plug the board into the charger either way....the charger i have is the one that tower has that looks just like the thunder t6 multi charger....but its clone i guess youd say...
02-01-2012, 05:03 PM | #7 |
| Re: stupid question..... Last edited by ik632; 02-01-2012 at 05:10 PM. |
stupid question..... - Similar Threads | ||||
Here's a stupid question... | IHeardARuckus | Comments, Suggestions, and Help | 3 | 01-23-2008 09:36 AM |
Stupid Question because I'm computer stupid! | RXcrawler | Chit Chat | 19 | 10-18-2007 02:45 PM |
stupid question | Kranberry | Newbie General | 11 | 04-10-2007 04:46 PM |
stupid question | JIMMYBOB | Tamiya TLT Crawlers | 3 | 02-11-2007 08:03 PM |
stupid question, but???? | kmoore | Newbie General | 3 | 10-18-2006 07:22 PM |
