02-03-2012, 12:01 AM | #1 |
Quarry Creeper Join Date: Nov 2011 Location: Plano,TX
| POS FlySky GT-3B or POS FXR ??? SOLVED !!
So I have an unhacked Flysky GT-3B and 2 FX-R ESCs. The common denominator of my problem is of course the GT-3B. I do not remeber having this problem when I only had one vehicle programmed. On both ESCs - the GT-3B cannot consistently find neutral. I have binded the receiver several times. Calibrated the ESC at least 20 times. ESC trims at 0 and EPAs at 100%. When I drive either vehicle I am CONSTANTLY adjusting trim to keep the vehicle from creeping off. I dont mean every 20 - 30 mins. I mean every 5-10 seconds when sitting still. I have even installed Tekin Hotwire and set the neutral bandwith at 90 - no good. set it at 50 - no good. set it at 20 - no good. I can LITERALLY touch the trigger with a feather - yes - I have tried it and the vehicle jumps and moves. Yes - you read that right. A feather. GT-3B TX/RX trash - or FXRs trash? I kinda doubt its the FXRs. I do not have another radio to try. Again - when I just had the XR10 - I dont remember having this problem at all. But now with 2 vehicles - they both act the same. Any suggestions. By the way - I've been running rc cars, trucks and helis for 20 years. Just never used a $35 radio to control them. IT WAS THE POS FLYSKY!! Last edited by bbking9; 02-05-2012 at 11:26 PM. |
02-03-2012, 12:34 AM | #2 |
| Re: POS FlySky GT-3B or POS FXR ???
Try your other radio and also try plugging the ESC into the steering channel or 3rd channel. Calibrate as usual and see if you have similar issues or not. Try to narrow down the problem, my guess would be that it is in the radio...It would be odd to have two FXR's have this same problem at exactly the same time. If I had to pick something I would say it could be a bad throttle pot that is not consistent, that would cause the problems you are seeing...If that is the case and you are out of warranty you could probably source a new pot and that would fix the problem.
02-03-2012, 12:40 AM | #3 |
As stated in my original post - I do not have another radio. I will plug the servo into the throttle position and see what happens. Thanks. |
02-03-2012, 06:55 AM | #4 |
Quarry Creeper Join Date: Nov 2006 Location: out in boonies!!
You using one rx for both cars?
02-03-2012, 06:58 AM | #5 |
Rock Crawler Join Date: Oct 2011 Location: smithville
Hey dude sucks that you are having those problems. I havent had anything wrong with the gt3b so dont hate it yet haha. Maybe ask losikid since he made the hack, he should know much more about it and should set you straight.
02-03-2012, 07:25 AM | #6 |
ive got both , FXR and the Flysky that i run on multible trucks and never had an issue. maybe you got a lemmon
02-03-2012, 09:40 AM | #7 |
Frank, my radio has not been hacked. Using 2 different RXs. Odd thing is - when I just had the XR10 - I never noticed a problem Last edited by bbking9; 02-03-2012 at 09:43 AM. |
02-03-2012, 10:34 AM | #8 |
Pebble Pounder Join Date: Oct 2008 Location: Downieville
It's the GT3b. I can't remember the reason, but 2 esc's won't work with it. Hack it and it will work fine.
02-03-2012, 11:00 AM | #9 |
Remembered what it was. The third channel on the stock Gt3b was made for a brake servo. It only works in one direction(ie Brake off to brake on and back).
02-03-2012, 11:36 AM | #10 | |
| Re: POS FlySky GT-3B or POS FXR ??? Quote:
02-03-2012, 12:16 PM | #11 |
you are correct smr.
02-03-2012, 04:27 PM | #12 |
Video?
02-03-2012, 05:09 PM | #13 |
losikid, i'll try - but im doing good to post pics !!!!
02-03-2012, 05:32 PM | #14 |
Rock Crawler Join Date: Oct 2011 Location: minot
setting up a youtube account is as easy as joining this forum (i took forever to do it cuz i want sure about it) just do that and then click the share button under your vid on your account page at youtube. losikid's hack ROCKS! |
02-05-2012, 11:27 PM | #15 |
| Re: POS FlySky GT-3B or POS FXR ??? SOLVED !!
It was the POS FlySky.
02-05-2012, 11:45 PM | #16 |
| Re: POS FlySky GT-3B or POS FXR ??? SOLVED !! |
02-06-2012, 12:16 AM | #17 |
02-06-2012, 08:08 AM | #18 |
replaced recvr and tx with spektrum dx3c. works perfectly. if you wanna buy the tx (with the "bad pot") and 2 rxs. plus 1900 lipo. PM me. |
POS FlySky GT-3B or POS FXR ??? SOLVED !! - Similar Threads | ||||
Does a stock Flysky have a 3 pos 3rd channel? | Hoyta | Electronics | 2 | 10-03-2011 06:00 AM |
my pos | XSRCdesign | Chit Chat | 31 | 08-02-2011 08:26 PM |
2-pos to 3-pos dig converter advice | wantAsummit | Team Losi Comp Crawler | 0 | 08-18-2010 03:01 PM |
2-pos to 3-pos dig converter advice | wantAsummit | Axial AX-10 Scorpion | 0 | 08-18-2010 03:01 PM |
