06-24-2006, 04:04 PM | #1 |
Newbie Join Date: Nov 2005 Location: North
| Receiver range problem
I bought a Futaba bottom of the line AM receiver a few months ago and just now got it in the vehicle to discover it has a range of about 20 yards before it starts losing communication. I've tested all the other equipment (I have quite a few radio sets/esc/etc) and have narrowed it down. I've checked the antenna wire and popped the top off the receiver and all looks well. Anything else I should try before sending it in for warranty? |
06-24-2006, 08:06 PM | #2 |
I wanna be Dave Join Date: Mar 2006 Location: One Legend.
60 feet isn't too bad for a cheap AM radio... Especially in crawling... I never get that far away anyway! |
06-24-2006, 09:45 PM | #3 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
What kind of warranty did you get that is valid a few months after you bought it?
06-25-2006, 06:55 AM | #4 |
What do these little pots inside on the circuit board do? Could it be "out of tune"? Let's say little Jaurez drank too much Corona the night before he put it together... |
09-02-2006, 02:03 PM | #5 |
Rock Crawler Join Date: May 2006 Location: United Kingdom,Scarborough
| i get about 600 yards .It cost me about £250 for my transmitter and heavy duty servos Mine is a 10 Model Memory Transmitter, megatech 3PM-FS with a T3PM DIGITAL PROPORTIONAL R/C SYSTEM This is the one of best controller rock crawler controller futaba brought out i think? not bad for a 12 year old Last edited by Moondust1950; 09-03-2006 at 08:04 AM. |
09-02-2006, 10:24 PM | #6 |
A few things to check: What transmitter are you using, and is it the same band as your receiver? If you're using a TQ3, and your cheapo Futaba is on the 75MHz band, you'll get extremely limited range. Check the shift of the transmitter and receiver. AM sets have shift issues just like FM. Futaba and Hitec are negative shift, JR and Airtronics are positive. (I don't know what shift the 27MHz band is, but all AM 27 band equipment is compatible, regardless of brand. This goes for crystals as well.) If I had to guess, I'd say you're trying to use it with a TQ3 and it's on the wrong band. So 60 feet is pretty good. |
09-03-2006, 04:44 AM | #7 |
| crystel
or change the cystels in ur controller and in ur receiver
09-03-2006, 01:04 PM | #8 |
I bought this setup complete as a Futaba combo (tx, rx, x'tals, servo and sc). Would this shift thing be an issue if all my electronics were matching? |
09-03-2006, 01:29 PM | #9 |
RCC Addict Join Date: Mar 2005 Location: Saginaw
Just a thought - are transmitter batteries fresh?
09-04-2006, 09:53 AM | #10 |
| receiver answer
is ur controller the make as ur esc 1) change crystels 2) check batteries in controller 3) check esc is setup correctly 4) check wiring on esc,ariel on esc and antenna on controller check all for things and let me know how u went on...... regards james |
09-04-2006, 01:36 PM | #11 | ||
09-04-2006, 01:44 PM | #12 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
you will want to check the placement of your antenna AM is extremely sensitive to interferance and any metal to metal contact of having the ant. wire to close to motor wire/servo wires/battery connection could all kill your reception. do a double check of all your harware making sure it's good and tight lol that sounds bad
09-14-2006, 01:36 PM | #13 |
| receiver range
so has any of this advice worked?
