02-04-2012, 07:58 PM | #1 |
Rock Crawler Join Date: Dec 2011 Location: Northwestern PA
| Goofy servo - busted?
I have a servo that came stock in a Duratrax Vendetta SC. It took a beating, and now when it is powered on, it goes 100% in one direction. Then when I steer on the transmitter, one way does not steer at all and the other way steers all 180*. Is there any hope for the servo? I've tired it with different receivers and transmitters; it's definitely the servo that is the issue. Thanks in advance! Josh |
02-04-2012, 08:46 PM | #2 |
Quarry Creeper Join Date: Nov 2006 Location: out in boonies!!
| Re: Goofy servo - busted?
Sure ya didn't strip servo horn?
02-05-2012, 08:17 AM | #3 |
| Re: Goofy servo - busted? |
02-05-2012, 09:22 AM | #4 |
sounds like a bad servo, possibly time for a new one.
02-05-2012, 10:06 AM | #5 |
| Teeth missing/folded over on an internal gear so now the centering pot. is misaligned. Centering pot dead The centering pots are usually under the output gear (the gear that your horn bolts onto), check under that, make sure there isn't some kind of small plastic bracket, dogbone, or locator missing and the pot's not following the output gear Or just crack with a couple dollars and get a new one. |
02-05-2012, 10:59 AM | #6 | |
| Re: Goofy servo - busted? Quote:
Goofy servo - busted? - Similar Threads | ||||
HS-645MG servo acting goofy. | KevMc | Losi Mini-Rock Crawler | 8 | 02-16-2009 06:55 PM |
Servo Wiring Busted. | NitroX | Electronics | 2 | 02-06-2009 06:46 PM |
NSX Forum, Guy gets BUSTED. Spam by a pheodophile, just insane BUSTED | Kingofthehill | Chit Chat | 5 | 01-01-2008 12:28 AM |
this is about goofy | powertuned | General Crawlers | 4 | 04-16-2005 05:52 PM |
