02-09-2012, 05:25 PM | #1 |
Quarry Creeper Join Date: Aug 2011 Location: Sacramento
| 3channel tx question
n00b alert: so i have a 3 channel tx(associated xp3-ss) and a 3 channel reciever. the tx has an auxiliary button as the 3rd channel. so if i hook up a second servo (as in 4ws) to the 3rd channel...will it work?
02-09-2012, 05:46 PM | #2 |
Rock Crawler Join Date: Nov 2009 Location: poteau
| Re: 3channel tx question
does the radio have a 3 position third channel? if not, the the short answer is no. if yes, then yes. you can hook up the rear steer servo with a Y harness off the front servo but it would be 4ws all the time. or you could look up HEYOK here on the forum, he makes controllers and i think he has one that will allow control of rear servo off a 2 position 3rd channel switch.
02-09-2012, 06:06 PM | #3 |
it is just a button i would assume a toggle button
02-09-2012, 06:08 PM | #4 |
if its a 2 position (on, off) then look up HEYOK, he can hook you up.
02-09-2012, 08:28 PM | #5 |
Ok thanks man
3channel tx question - Similar Threads | ||||
Will this 3channel work with dig? | dogsofwar | Electronics | 4 | 07-10-2011 08:06 PM |
New 3channel Spektrum radio | Aaronb | Newbie General | 2 | 12-27-2009 06:56 PM |
3channel to 4channel? | prusik333 | Electronics | 0 | 09-21-2008 09:26 PM |
Which 3Channel Radio For DIG on Clod and AX10/TLT? | TheHeadHunter | Electronics | 1 | 08-22-2008 05:04 PM |
Need some advice for a 3channel radio | odonx | Electronics | 4 | 05-14-2008 04:48 PM |
