Thread: capacitors?
Old 02-20-2012, 05:53 AM   #1
Default capacitors?
Hi, new to the forum. New to crawling. Not new to RC's and soldering. I have owned brushed motors in the past, and i mean in the PAST! but never had a brushed motor without capacitors. Back in the day, the brushed motors i got already had them on. I must of gotten used ones. I cant remember that far back
My question is, are they needed? If so, what size and which tabs to put them on?
I got my hands on a lnc and found a good deal on a 65t motor, so i bought it and it has no capacitors on it and i'm having a hard time finding info for this subject.
Thank You for any replies!
Wille is offline   Reply With Quote
Old 02-20-2012, 06:18 AM   #2
Default Re: capacitors?
I'm no expert, but from what I've read is that with 2.4 radio equipment the capacitors aren't really needed anymore. May have to do with modern motor/esc technology also, I don't really know. In a pinch I ran my old (late 90's) AM radio gear on my Honcho with no capacitors on the motor and it only had minor glitches. Nothing like when a capacitor would come unsoldered from the can back in the day on my touring car though.
Big Daddy is offline   Reply With Quote
Old 02-20-2012, 06:27 AM   #3
The tech at my LHS told me that you do not need capacitors on crawler motors because they are not turning as many RPM's.
scorpiondave is offline   Reply With Quote
Old 02-20-2012, 07:46 AM   #4
Motor caps were really needed with AM & FM radios, not so much with the 2.4ghz.
I would still use them though.
Look closely at your motor, today, most of the caps are tiny chips not the bigger ones we used way back when (I started running RC cars in the late 70's.......). The new caps may be sitting on a small PC board on the endbell between the brush hoods.
Charlie-III is offline   Reply With Quote
Old 02-20-2012, 12:13 PM   #5
New here, but I agree
Sivob is offline   Reply With Quote
Old 02-20-2012, 03:35 PM   #6
They won't hurt, but they really aren't needed with the stock Losi radio. A 65t motor isn't the best choice for a LNC though, 35-45t would be much better.
indiana mudcat is offline   Reply With Quote
Old 02-20-2012, 04:52 PM   #7
Thanks for the replies, greatly appreciated! but why not a 65t? dont the higher turns provide more torque for crawlers? Im learning
Old 02-20-2012, 05:22 PM   #8
The LNC's are geared low, very low. Sometimes you need wheelspeed, even a cheap integy 35t will have more torque than the stock throw away 55t.
Old 02-20-2012, 05:48 PM   #9
sooo... could i go higher on the pinion to make up the difference? Or do i have a paper weight?
Old 02-20-2012, 06:12 PM   #10
You can try to gear it up, just keep an eye on motor & ESC temps.
You could also up the pack voltage (like change from 2S LiPO to 3S).
capacitors? - Similar Threads
capacitors for FX-R Flyin Hawaiian Electronics 3 04-15-2009 05:46 PM
Capacitors Shaun Electronics 1 05-09-2008 09:33 PM
capacitors??? gigercrawler Electronics 9 10-25-2007 07:23 AM
Capacitors Crawlerdude75 Newbie General 6 02-18-2007 08:33 PM
What value of capacitors do I need? AdamF Electronics 9 01-25-2005 02:21 PM
